Product Updates From Zeta Products
Stainless Steel Rear Bumper Cover
I just ordered mine, and will post photos & review when it arrives. Considering the source, I already know that this will be of high quality. Compared to the Honda Rear Bumper Applique selling for $40.00 plus, this item is a much better investment for bumper surface protection, and looks a LOT BETTER!
Thanks Angelo!
Thanks Angelo!
Just another install of the door sills. Thanks to darkcambria for the heads-up about the rears:
Angelo, maybe make a note in the install instructions that the rear sill plates need to be bent a bit before install. Really, only the last inch or so on each end needs to be flexed up a bit, and it's mostly just the top portion that needs it. Doing so helps the plate to adapt to the door sill much better, as without the bends, the plates are too long and want to spring up from the sills.
Thanks for the hint. I will revise the install info.
I added a couple of great new items to the side. Let me know what you think...
2007 Honda Fit Altezza Tail Light Kit.
2007 Honda Fit L.E.D. Tail Light Kit - Smoke.
You can find all these items here.
#32
#37
Anything is possible but NOT recommended. There would be too many issues with sealing after. How about just painting the outside? I just added this item to the site:
JDM LENS SPRAY PAINT. Assorted Colors.
Use this high quality paint to spray headlights, tail lights, side markers. NET: 80ml. Made in Japan.
#38
Check out this thread. https://www.fitfreak.net/forums/fit-...ted+headlights
That might help you out if your serious about painting them.
Gojulas
17
09-27-2015 04:55 PM
zetaproducts.net
Zeta Products.net
10-14-2010 10:24 AM
xk319
02-15-2008 08:24 PM
