Winter Wheels, steel rims
I searched for compatible 14" steel rims and found Geo Storm wheels are the perfect 14" steel replacement. 6" wide with more than adequate clearance of calipers, 56mm center hole and 45mm offset. Half inch wider than stock, they take the 185/65 14 tires very well. I bought my four rims for $5 each. Saturn S models give a 14 x 5" wheel that fits good though it has only a millimeter clearance to the calipers and the 57mm center hole is not perfect but adequate. Saturn advantage is a plentiful supply at the auto wreckers. Acura Integras provide 14 x 5.5" rims that look good also.
k-man
12-12-2012 06:21 PM
Sabiokah
04-20-2010 05:22 PM
