SSR line up
SSR line up
SSR utilizes high quality materials with precise technique to continue to manufacture three piece wheels allowing no room for compromise. The same process used over 35 years ago by SSR with the very first three piece wheel, MK1, is still used today and known worldwide. With great support and confidence in technique and quality, SSR is proud to continue to manufacture three piece wheels.
More styles available.
Click here to see list of available wheels.
Wide range of sizes to best fit your vehicle
The three piece wheel that is made up of an outer rim, inner rim, and center disk enable to set the rim width and offset according to your vehicle and specifications in various sizes. SSR’s three piece wheels come in four kinds of center disks to customize your wheel for proper brake caliper clearance.
Super lightweight and high strength *HTM inner rim
The outer rim and inner rim receive the most impact. A high strength inner rim is required due to heavier loads during cornering. By heat treating the inner rim the strength is increased and allowing the use of thinner material. Therefore, we can produce an inner rim that’s high in strength and lightweight at the same time. This heat treated rim has cleared severe tests giving the rim its high quality. SSR’s three piece wheels with a HTM inner rim can withstand high speed corners with great G force while maintaining high strength drawing out the maximum potential of the vehicle.
*HTM means Heat Treatment Manufacture
Forming high quality performance wheels
Taking into consideration the amount of strength needed for each part, SSR uses separate grade of aluminum according to its purpose on the three piece wheels. To make the most out of the materials, each part of the rim is closely calculated and designed for the perfect thickness and balance throughout the wheel. For quality automotive performance, lightweight and high strength is always required. SSR’s knowledge of performance has derived from professional automotive experience to form excellent wheels that are super lightweight and high in strength.
Do you have any suspension or brake upgrades?
MS1R 16inch - Starting at 15.65 Lbs.
SP1R 16inch - Starting at 17.70 Lbs.
SP2R 16inch - Starting at 15.02 Lbs.
go to More-Japan.com/SSR.php and click the 'Inquiry' button at the bottom. Fill out the information then we can get you the correct fitment for the wheel that you want.
SP1: 18.46 - 21.93 Lbs.
*MS1R: 20.17 - 23.99 Lbs.
18inch
SP1: 19.94 - 24.58 Lbs.
MS1: 22.49 - 27.76 Lbs.
These weights are ranging from lowest 17inch and 18inch weights to the highest weight. Specific weights depend on wheel sizing according to you vehicle and specs.
*MS1R available sizes are 15, 16, and 17 inches. MS1 available sizes are 18 and 19 inches.
Hi,
You can find a dealer with the SSR logo by their name and they will be able to set you up with the MS1R's and give you pricing.
http://www.more-japan.com/Retail-Sto...tor-sp-10.html
Specs:
SSR Professor MS1R - 16inch Specs
Unfortunately the price is per wheel.
SSR was actually the first company to offer a 3 piece wheel to the consumer market. We have also founded many other innovations like Semi Solid Forging and HTM. When you purchase our wheels you are purchasing the best in wheel technology.
Fit_Dr
02-28-2011 09:45 PM
