FS: J's Racing Brake Master Cylinder
Hello,
I just comparing the brake master cylinder/booster between GE8 and GK5, it looks both the Master cylinder and booster is NOT the same.
But the bolt pattern to mount the booster on the firewall, and the connection to the brake pedal is the same between both GE8 and GK5 (since the gasket and yoke have the same part number).
So most likely, you will be able to use this J's Racing Master Cylinder if you also change the brake booster to GE8 brake booster.
Of course most likely you will also need to make an adapter pipe for the hardline brake line. Having said that, I could not guarantee that everything will fit and work as easy as I describe above
Note: I still have the original Honda Fit GE brake booster if you are also interested in buying it too.
Thanks
Thanks
Onewheelofsteel
05-08-2019 11:43 PM
sabawballs
01-15-2014 05:00 AM
CelestialBlue
06-03-2012 02:22 AM
