Was able to put in my old VLEDS V3 Triton switchbacks for the front parking/turn signal light. I discovered my spare triton harness was already made for the 7443 bulb, so I didn't need to splice anything. Will wait til tonight to see if I will wire the dimmer or just leave it off. With automatic headlights, if the dimmer wire is hooked up, it will pretty much be dimmed all the time when it turns on with the headlights. I rarely just turn on the parking lights by itself now since we not have automatic headlights.
Finally got around installing the Acuity Gas Pedal Relocator.
As recommended by @USDM I set it to Setting "B". Can wait to try improved Heel-N-Toe action!!
Now I need the sports pedals on! Less than 2 weeks until Laguna Seca!
I tried positions B and C, but I settled on position C. I hope you like this modification as much as I do.
