Old 11-14-2016, 07:44 PM
skatana's Avatar
Gave her a bath during my lunch break.
  #882
Old 11-14-2016, 08:15 PM
FITEsq's Avatar
Skatana,
I really like what you did with it.
What size and brand/model tires you have on? I can't tell from the photo. I am in the market.
  #883
Old 11-14-2016, 08:23 PM
Fitster C.'s Avatar
My driver's seat peeled molding DIY repair
View at another thread: https://www.fitfreak.net/forums/3rd-...ml#post1358368
  #884
Old 11-14-2016, 09:30 PM
skatana's Avatar
FITEsq,
I picked up a set of LS Meshes from an Integra off the good ole craigslist and painted them white. They're standard size, 15x6 +45.
Here is a better shot of the wheels.
  #885
Old 11-15-2016, 03:25 AM
FITEsq's Avatar
Those wheels look great on the the FIT. It's something no one else will have.
I also like "Made in Japan" decal.
And that looks like a full custom chrome exhaust? Not just an exhaust tip. Did you modify the exhaust yourself?
  #886
Old 11-15-2016, 11:44 AM
skatana's Avatar
The exhaust is an HKS Silent Hi-Power. I ordered it off kamispeed. It's pretty easy to bolt on (takes about 30 minutes if it's up on ramps). You just have to make sure they didn't overdo the welds where the stock bolts thread in on the axle-back.
  #887
Old 11-15-2016, 02:41 PM
FITEsq's Avatar
Thanks Skatana!
Good idea.
  #888
Old 11-16-2016, 07:20 PM
ab30494's Avatar
Originally Posted by FitRaptor
Just installed here's the info.<br/>Amazon purchase<br/>-Headlights H4 stark 6k lm<br/>-H8: Calais fog golden color<br/>-7440 Partsam rear reverse led lights
EBAY: Switchback turn signals, sorry the best I can do with my iPhone. <br/>7440 Amber white high power turn signal light switchback projector led + resistor. Seller was esongbpn 99.6 positive feedback.
how well do they light up the road with the stock headlight assembly(dont remeber the name) I heard leds dont do so good without projector housings.
  #889
Old 11-20-2016, 12:19 PM
skatana's Avatar
ab30494,
I'm running LED's on mine and they light up the road pretty well. You might have to adjust the aim a little after they are installed, but that's about it.
Here are the ones I'm currently running.
https://www.siriusledlights.com/coll...d-headlight-h4
  #890
Old 11-20-2016, 01:34 PM
hogwylde's Avatar
Today I passed a GK with my GE!
  #891
Old 11-20-2016, 05:30 PM
ab30494's Avatar
Washed it on this sunny cold day
  #892
Old 11-21-2016, 10:39 AM
Nothing exciting. Got it rustproofed.
  #893
Old 11-21-2016, 02:21 PM
Fuelish's Avatar
Had the cold weather grind on start (VTC actuator???) again yesterday morning at work...2 mornings in a row it's been cold enough to make it do so since purchase in June..I work 12 hour night shifts at the local hospital, car sits from 18:35 until 07:25, give or take. Parked it outside of our garage overnight last night (was off), and tried the suggestion of "bumping" the starter to slightly turn the motor but not enough for it to start. This a.m. was the coldest yet here in east TN since purchase, 29*F. "Bumped" it twice, started normally, no noise as opposed to on the previous 2 mornings, when the temp was just above 30*F. If bumping the starter is something of a workaround, I'll just do that, if Honda isn't willing to offer up a cure....I'm a night shift nurse, I ain't got the time or patience to be running back and forth from the dealer to hear that "the problem couldn't be replicated," or "We've never heard of that on Fits before" or "It's normal, nothing to worry about, it's not harming anything..." This noise has to be affecting something, whether they admit to it or not.....will try again tomorrow - supposed to be about the same a.m. temp, debating on whether to bump the starter or just see if it makes the noise again....but yeah....sorry for the novel
  #894
Old 11-21-2016, 03:51 PM
first honda's Avatar
Have your phone ready to record it next time and bring that to the dealer
  #895
Old 11-21-2016, 04:16 PM
KentFinn's Avatar
I would suggest a HCP for anyone working a night shift, male or female, especially at a hospital. Drugs are there and so are assorted whackos. Tennessee's Handgun Carry Permits are relatively inexpensive and the requirements are just common sense ones ... over 21. non-felon, total 8 hours training (class room, range).
  #896
Old 11-23-2016, 03:25 PM
otbiker's Avatar
Fixed Bumper
New to me 15 EX-L. Removed the "insert" on top of the grill. That gave me enough access to insert stiff rubber floor matting between the beam and the top of the bumper cover. Two pieces about 4" long did the trick. Things are now aligned properly. About a 20 minute job that does not require removing the bumper cover.
  #897
Old 11-23-2016, 05:15 PM
tbFit's Avatar
Interesting, was this to correct the all-to-familiar sagging front bumper issue? Did you do this from under the car or the front? Our Fit has a slight sag, hence the queries and this sounds like a possible fix?
  #898
Old 11-23-2016, 06:27 PM
otbiker's Avatar
Yes, this corrects the sag. There is a "filler" piece between the radiator and the grill, from under the hood. Remove 5 plastic push pins and pull the grill forward. That allowed me enough room to place the rubber matting on the top of the beam, wedged against the top of the bumper cover.
  #899
Old 11-23-2016, 07:01 PM
Been planning to do this. My 2015 EX has a sagging bumper, did you buy the rubber matting or just made it from scrap.
  #900
Old 11-23-2016, 07:19 PM
tbFit's Avatar
Ok great! That worked. I used a 20" or so piece of pipe foam (99 cents at Lowes for 6') I had lying around and lifted up the bumper as I wedged the foam on top the bar. The sag is reduced over 50% and is hardly noticeable now. If I decide to get more aggressive, I'll consider adding another layer, perhaps the larger diameter pipe foam combined with the smallest size I already used.
Quick Reply: What did you do to your GK Fit today?
