$2000 + Fit Mod Club!
#425
I added up his parts list, it's a little over 9k.
If you love the car enough, want to keep it for a long time, and have the disposable income, why not? There are plenty of civics out there with 10k just under their hood.
Perhaps you were talking about getting newer cars? I've also seen people drop 5 digits in modifications on new bmws.
Tuners. 😛
Tuners. 😛
#427
Welp, add me to the club.
SC, ITR BBK (calipers, rotors, pads, lines, fluid), rear sway, short shifter, Koni orange shocks, swift springs, crz brake master, civic clutch slave and OEM Armrest console!!!! (best mod IMO)
That's probably atleast 4k+ Then I need need track tires, track brakes, track wheels, new tint.... Ughh...One day i won't sink money into my cars.
#428
#429
Installed Items:
Honda Fit OEM Genuine Parts/Factory Options: Cargo Cover, JDM Fit “She’s” Armrest/Center Console, Sports Pedal, JDM LED Tail Light, JDM Fit “RS” Emblem, JDM Door Mirror (Auto Folding, LED Turn Signal, Heated Mirror, Smart Key Sensor Ready), JDM Fit Auto Folding Wiring for Door Mirror, JDM Fit RS REAR Bumper, Carbon Fiber B Pillar Trim, Carbon Fiber Door Switch Trim, JDM Dashboard Aluminum Trim, JDM Carbon Fiber Fabric Door Handle with Custom Yellow Stitching, JDM Hand Brake Cover, JDM Interior LED Light with Plasma Cluster, JDM Red and Blue Ambient Light, JDM Fit Cup Holder Ambient Light, JDM Fit RS Illuminated Door Sill Trims, JDM Fit RS Dark Grey Inside Door Handle, JDM Fit RS Hazard Light Switch, JDM Fit Cooled Glove Box Vent, Fog Light/VSA Combo Switch, Fog Light Switch, Honda Fit Cargo Tray
Rough Calculation Subtotal for the above are around $5,300
Honda (Non Fit) OEM Genuine Parts: CR-Z Shift Knob, CR-Z Lower Engine Cover, CR-V Illuminated (Back Lighted) Door Mirror Switch, Civic Seat Belt Bolt Cover, Honda "H" Red Emblem, JDM Fit Shuttle MODULO (Honda Access) Front Lips and Front Garnish, Honda S2000 Exhaust Tips, Fuel Filler Cover with Key, JDM Honda Insight Auto Tilt Wiring for Door Mirror, Rear Trunk LED Light with Switch, Acura TSX HomeLink/Map Light with LED Bulb, JDM Stream DBA-RN6 RSZ S Package Aluminum Foot Rest Cover, Honda CR-Z OEM Airbox Snorkel, Honda Accord H emblem and VTEC engine cover emblem
Rough Calculation Subtotal for the above are around $1,800
Mugen Parts: JDM Mugen Fit RS Trunk Mat, Interior Rear View Mirror Cover (Red Color), JDM Fit RS Mugen Rear Under Spoiler, JDM Fit RS Mugen Rear LED Fog Light, JDM Fit RS Mugen Side Skirt, JDM Mugen Blue Door Mirror, JDM Mugen Fit RS Floor Mat (Red 2nd version), JDM Mugen CR-Z Airbox
Rough Calculation Subtotal for the above are around $4,500
RECARO Parts: JDM Recaro Seat Rail, Recaro Seat Belt Cover
Rough Calculation Subtotal for the above are around $850
Takero’s Parts: Takero’s Carbon Fiber Rear Wing Add On
Rough Calculation Subtotal for the above are around $400
Rockford Fosgate: Power and Signal Wiring Kit, Battery Terminal, Fuse Block and Distribution Block
Rough Calculation Subtotal for the above are around $250
Misc. Aftermarket Parts: J’s Racing Steering Wheel with J’s Racing Carbon Fiber Trim, PIAA Sports Horn with Relay, Audio Technix 1/0 AWG Big 3 Wiring and Fuse Block Kit, Monster Cable Monster 300 Crimpless Ring Terminals, Broadway Optics Rear View Mirror, GTMat Ultra 80mil Sound Deadening CLD Tiles, SoundAway MLV Sound Barrier, TheFoamFactory Neoprene Closed Cell Foam and Acoustic Foam, 3 JDM Accessories power socket, T1R Oil Filler Cover, Shorter Carbon Fiber Antenna, CNC Machined MDF Dynaudio Esotar 650 Spacer, PIAA 15224 H4 Style Xtreme White HeadLight, PIAA 15211 H11 Style Xtreme White Fog Light Bulb
Rough Calculation Subtotal for the above are around $2,000
DIY Modification: Throttle Body Coolant Bypass, Extra LED Brake Light in Lower Section of JDM LED Tail Light (V-LED), Turn Signal Light Blink with Alarm (Arm/Disarm), Red & Blue Button on The Plasmacluster Air Purifier
Rough Calculation Subtotal for the above are around $200
Performance Parts: Denso Iridium IK22 5310 Spark Plug, T1R Header and Plug Non Fouler, Vibrant Performance (11619) J-Style Fitting & (11621) Straight Fitting , Skunk2 O2 Sensor Extension Cable, AEM UEGO Digital Wideband O2 AFR Gauge (30-4110), Auto Meter 2204 Mounting Cup with Modified Garmin Portable Friction Dashboard Mount, ScanGaugeII, Jackson Racing Injector Connector Honda to Denso, J’s Racing High Pressure Radiator Cap, J’s Racing Thermostat, J’s Racing Engine and Transmission Oil Drain Bolt, Car Garage Amis Meter Pod with Custom Leather and Yellow Stitching, DEFI-Link, Advance BF Boost and Water Temp Gauge with Controller, Denso 195131-9520 265lph Drop In Fuel Pump for Nissan GT-R, JDM Mugen CR-Z Airbox, Sprintex Super Charger Version (Concept-2) with Restrictor Removed, Polished and Ported, Acura RDX Fuel Injector, Honda Civic Si Resonator and Muffler with 2 1/4in Custom Mandrel Bent Stainless Steel Axle Back Piping, Vibrant Performance 1790 Stainless Steel Resonator, AEM F/IC-6 30-1910, Boomslang Plug & Play Wiring Harness for AEM F/IC-6
Rough Calculation Subtotal for the above are around $8,000
Wheel and Tire: BBS FORGED wheel model RF-509 18x7.5 et48 (including Full Size Spare), BBS RED Wheel Lock and Hub Cap, Michelin Pilot Super Sport 215/40ZR-18, ARP (1007712) Extended Wheel Stud, H&R 15mm Spacer (Front & Rear)
Suspension: JDM Ohlins BTO DFV Coil Over with Eibach Spacer250, Eibach Spring Helper250, Eibach Torsion Release Bearings TRB250, Eibach Isolator250, Honda Insight Aluminum Front Lower Control Arm, SPC Camber Bolts, Spoon Front Stabilizer (Sway) Bar, Progress Rear Sway Bar, Cusco Type 2 Lower Sub Frame Bar (4 point), Kuo’s Garage Master Cylinder Stabilizer & Front Strut Tower Bar (EBMC Bar), Spoon Rigid Collar for Front & Rear Axle
Brake: Modified Subaru BR-Z Brembo GranTurismo with Type III Rotor, Coleman Racing Custom Rotor Hat & Bracket (Type III Hard Anodized), J’s Racing Brake Master Cylinder, Goodridge Stainless Steel Braided Brake Lines, Hel Front Custom Stainless Steel Braided Brake Lines, Kurvey Girl Titanium Banjo Bolts, JDM Integra DC5 Type-R Rear RED Brake Caliper with EBC Brake Pads, JDM RS REAR Axle with REAR DISK BRAKE Conversion and filled bushing, Wilwood Rear Brake Hat (Type III Hard Anodized) with Wilwood Bolt Kit and Safety Wire, Custom 13in Rear Disk Brake Rotor with Brembo Type III Slotted Design & Bracket (Type III Hard Anodized) from Coleman Racing
Rough Calculation Subtotal for the above are around $16,000
GRAND TOTAL ROUGH CALCULATION SPENT SO FAR:
$39,300
If I am lucky enough to buy the parts that I plan to buy in the future below,
it should cost another $8,000 to $10,000,
so the total should be near or at or above $50,000...
and that don't include the money that I loss from the "previous parts list below" that I had sold (depreciation)
no wonder I am broke right now ...
To be Bought in The Future:
JDP Engineering Carbon Fiber Hood (Painted White), JDM Recaro SR-7 ASM Limited Ruby and ASM Seat Belt Protector, Navigation Head Unit, Upgrade Front Speaker into 3 way Dynaudio Esotar Active System with Dedicated DSP and Power Amp, Under Seat STEREO Front Subwoofer, Adjustable Front Sway Bar Links (13in), SAMCO Yellow Coolant Breather Coupling Reducer Hose with Clamp Kit, Spoon Larger Throttle Body with Port Matching
Previous Parts: Bilstein B14 Coil Over, OZ Racing SUPERTURISMO GT wheel size 18x7 et42, Gorilla Wheel Locks, K&N Typhoon Intake, K&N Drop In Air Filter for CR-Z OEM and Fit OEM Airbox, CR-Z OEM Airbox, USDM Fit Center Console, USDM Fit Door Sill Trims, P300-10 Punch Powered Subwoofer
$39,300
Last edited by BMW ALPINA; 02-07-2016 at 11:40 AM. Reason: Recalculate again and again and again :)
#433
Felix and Guiness are/were probably both right near Alpina.
But jeez.
That's wild.
Even between the S2000 I hope to buy shortly and my Fit (including both purchase prices) I don't intend on getting to that number.
And I've got expensive tastes.
But jeez.
That's wild.
#435
Hmm... We may have to chat one day. I've been tempted to run COTA for a while now once I move on from autocross.
If you ever run MSR Houston, let me know. I'm usually there on a fairly regular basis.
#436
Felix69 was well into the $80k mark. I think he is the winner of the most money put into a fit.
Guiness, kelsodeez, and jdmchris(aside fromt his sponsors) all have the same level of builds with similar money invested.
#437
If you've run at MSRH, then COTA should be easy to pick up. One of our buddies took a 09' Auto Fit with shitty tires and springs then tailgated some P-cars and a Viper from 3-7. Granted it was the blue group, but it was hilarious. I might be out there in March with some slicks and JRZ two way
#440
Current Fit - Nowhere near $2000
First Fit -
J's lip/grill - $600
Advan Kreuzer XII + 195/50/15 Yoko S.Drive - $750 (all new, crazy deal on the wheels)
Tein S.Tech - $130
RS*R C&K - $90
J's Type S Spoiler - $230
Buddy Club shift knob - $40
I still fell short (1840ish) hahaha
S2000-
J's Lip/Canards - $1260
Recaro Pole Position TUV/Side rails - $1300
HKS Hipermax IV GT - $1220
J's 60RS Ti - $100
J's S2 RCA - $305
Mugen Compliance Bushings - $110
Arvou Shift Knob - $100
NSX-R Shift Boot - $130
Mugen License Plate Bolts - $40
ASM License Plate Bolts - $60
ARC Ti Cooling Plate - $230
Honda Access Floor Mats - $300
Other stuff I've forgotten about.
I think I'm okay on that one.
First Fit -
Tein S.Tech - $130
RS*R C&K - $90
S2000-
J's 60RS Ti - $100
J's S2 RCA - $305
