JCrim's Road Racing Thread - Stay Tuned!
#581
Hey man i got the wheels mounted today and they look awesome. I am currently having some issues with my tpms sensors giving me a light on my dash, Im hoping its not because they are incompatible with these wheels but more an issue of me just needing a service kit for them...
i dont recall if your fit is an 07 or 08 but if you had sensors swapped into these, did you encounter problems?
personally, i dont use them anymore because race car, i just deleted the light. lol
PICS!!!
#582
Btw j, thx for yesterday...cant believe the difference it made!!! and my a/c is fully functional!!! woot! lol
#583
oh good, that makes me feel a little better that the sensors should work with these wheels. Ill have to order the rebuild kits and take it back to the place for them to fix what they should have done in the first place. ill post up some pics when i clean everything up.
#584
Hopefully the shop that did your service didn't damage a sensor, the OEMs are 55 dollars a pop plus S&H and TPMS resetting fee if any.
#585
If your TPMS system was working fine before swapping the sensors to the new wheels then it may be an installation issue. I've witnessed first hand during the transfer and installation of GE8 TPMS sensors from the OEM Sports to an aftermarket Drag wheel. No rebuild kit was needed, just make sure to not damage the sensor during bead breaking, transferring/mounting the sensor (gotta torque it to 15 inch lbs if I remember right) and tire removal/mounting.
#587
meh...why bother...TPMS is just a crutch for people who dont know or dont want to take time to check the tire pressure themselves every week. fill those 6ul's with nitrogen (has spot for 2 valve stems....USE IT) and call it good. refill as needed and JDM FIX THAT MUTHA!!!
#588
haha i totally agree with this 100%, i check my pressures manually all the time any and wish this wasn't even included with newer cars but i feel like since it is i just want it to work and would rather not rip apart my cluster to put tape on it just yet... that's all haha
#589
#590
fitflowjoe, I like your setup! Ive been wanting to run a reverse staggered setup. I love my HP+ pads too, great daily pad. If you can, try some track only pads. I run hawk blues are I love them even more than the HP+ on the track. Though they do stain wheels/paint...
#591
I will also do a complete BBK from a type R on my fit.
#593
So once the new rulebook is out and rule is official... upgrade time
Also looking at doing this:
Brake Kits - Performance Pads, Rotors, Calipers & Brake Upgrades
OR... looking for the JDM rear disc conversion with a local hook up... but then buying replacement pads and rotors is gonna be a _itch.
#596
Me too !!! There might be some rule changes in SCCA ST Class next year... and BBK are allowed now (And 88-89 Civic are out !! THANK G O D )
those fast brakes are what I plan on going with front and rear. should be more than enough.
you have oem rear disc??
#597
J, I found this and had to share... Ohlin makes a coilover kit for our car !!!
tBbg@TXyV/ll@gnmc`@i`o`m
Now i have no idea what that website says...
#598
