2009 911 gt3/gt3-rs
2009 911 gt3/gt3-rs
Face-lift for the 2009 911 GT3/GT3RS
We snapped the new Porsche 911 GT3 RS in the French mountains where it was testing alongside the current model which was released in Europe in October 2006 and in North America in February 2007. It will keep the 'GT3 RS' side sticker and the special coloured wheels, the decorative stripe, contrast-painted outside mirrors, rear wing endplates, and roll cage. The new GT3 RS will keep its top-speed of 311 km/h and a 0-100 time of about 4 seconds using a 415-hp engine.
Official Porsche Video
Driver: Walter Röhrl
YouTube - 2010 Porsche 911 GT3: First Video
- Will be revealed in Geneva Motor Show (5th ~ 15th March 2009)
- No DFI (Direct Fuel Injection)
- H6 / 3.8L (3,797Ci) / GT1 Block (Water-Cooled - DOHC - 4-Valves)
- Power output: 435hp @ 7,600RPM
- Redline: 8,500RPM
- CR (Compression Ratio): 12.0:1
- Variocam Variable Valve Control *NEW*
- 6-Spd Manual Transmission + RWD/LSD (Locking 28% ~ 40%)
- Automatic/PDK Transmission: -
- PSM (Porsche Stability Management) Never used on previous GT3's, fitted for the first time.
- SC (Stability Control) Can be switched off
- TC (Traction Control) Can be switched off
- Cd (Drag coefficient): 0.32
- Bi-Xenon: Standard
- Seats: - Sport Seats (Standard) - Sport Bucket Seats (Optional)
- New Sport Tires
- Larger Brake Discs (Cast-Iron w/aluminum bell)
- F: 6-Pistons / 380mm
- R: 4-pistons / 350mm
- Optional: PCCB (Porsche Ceramic Composite Brakes) 50% weight saving
- TPM (Tire Pressure Monitor): Standard
- 19inch Wheels with Central Locks
- Tires: - F: 235/35 19 x 8.5- R: 305/30 19 x 12
Weight: 1,395 kg / 3,069 lbs
Optional:
- Dynamic Engine Mount System (can be switched to "stiff" for track use) *NEW*
- Ride-height lift system: can raise the front axle by 30mm whenever there is a risk of grounding. *NEW*
- Price (in Germany): 117,000 € (Euro) (incl. 19% VAT)
Performance:
0 - 100km/h(62mph): 4.1s
0 - 160km/h(99mph): 8.2s
0 - 200km/h(124mph): 12.3s
80 - 120km/h(50-75mph): 5.9s in 5th gear
Top Speed: 312km/h (195mph)
- Redline: 8,500RPM
- New Sport Tires
Optional:
Performance:
Sid 6.7
09-06-2009 07:47 PM
Sid 6.7
03-10-2009 09:21 PM
