NSX engine in a S2000?
the cost:benefit isn't really worth it.
NSX engines are expensive and it would cost a lot to custom fabricate tranny mounting plates and motor mounts.
the NSX is only about 200 lbs. heavier, but it's a better balanced car. you'd be better off just picking up a used '91-'93 NSX.
I love the S2000, but IMHO the NSX looks 10 times better than the S2000 and would be a better project and safer to drive.
not sure why some would do that, but for 2jzgte s2000>C32B1 s2000 if there was one ever made imo. but yea "off topic" theres a red s2000 with a 2j down here... pretty fast. YouTube - 2jz s2000 from AD TURBO(skip to 1:07)
No Honda has ever had a horizontally opposed piston arrangement. This means the pistons fire 180 degrees opposite each other much like and "H" formation of the WRX boxer engine and some Porsche engines.
Building a eg civic with a mid mounted NSX motor has always been my dream car. The fit has more room for an engine in the back, but you would have to extend the entire chassis in the back to install a wider track. It would be sick though. If they ever bring over a renault clio v6 that would be the it.
Nick.
JacobAlexander
08-09-2014 10:23 PM
