Honda Odyssey problem
Old 09-21-2005 | 12:37 AM
toypup
Guest
Posts: n/a
I apologize if this is the proper forum. I've been having problems with my
Honda Odyssey for quite some time and I wonder if anyone could help.
Here's the history:
When I first got the minivan, it was brand new from the dealer. We had the
dealer install an alarm. Very soon after, the alarm started arming and
locking the doors all by itself. Later, it started to turn itself on and
off. By that, I mean, sometimes, I use the keyfob to arm the car, but only
the locks would work, but the alarm would not turn on. Then, without
warning, it would turn itself on, and the alarm would work like it normally
should. Eventually, the car horn would beep when I was driving, the lights
would flash, the dashboard backlight would flash, the turn signals flashed.
All which would happen intermittently.
We got the alarm replaced. Just as soon as it was replaced, the alarm
started arming itself and locking the doors automatically on an intermittant
basis. I brought it back, and they replaced it again, this time with an
upgraded model (or so they told me). The same thing happened with the third
alarm. This time, the dealer adjusted the alarm so it was less sensitive.
It continued to be a problem.
I just got my vehicle back from the dealer. They said they disarmed the
alarm. They also did some maintenance. When I get home, the engine light
is on and the TCS light is on. I use the windshield wiper and it gets stuck
in the up position. With some jiggling of the controls, I was able to get
it back. I get back in my car and now only the engine light is on. The
windshield wiper problem appears to be intermittent, just like all the other
problems.
Does anyone know what's wrong with this car?
Old 09-21-2005 | 01:30 AM
Abeness
Guest
Posts: n/a
Re: Honda Odyssey problem
From your description, it's starting to sound like a lemon. Can you try
another dealer? Perhaps they're incompetent.
Old 09-21-2005 | 03:30 AM
toypup
Guest
Posts: n/a
"toypup" <toypup@sbcglobal.net> wrote in message
news:sk4Ye.751$Ur.733@newssvr29.news.prodigy.net.. .
> alarm.
I should clarify: they told me they stopped the autoactivation feature of
the alarm.
Old 09-21-2005 | 11:31 AM
E Meyer
Guest
Posts: n/a
Sounds like a loose/bad ground connection somewhere. It also sounds like
your dealer is not competent. If you are still under warranty (the year of
this car is still a mystery to us), try a different dealer.
On 9/20/05 10:20 PM, in article sk4Ye.751$Ur.733@newssvr29.news.prodigy.net,
> Here's the history:
> problems.
Old 09-21-2005 | 01:30 PM
'Curly Q. Links'
Guest
Posts: n/a
> Here's the history:
> When I first got the minivan, <SNIP>
Is this Odyssey ten years old? It's a good idea to post the YEAR, MODEL,
and mileage of the vehicle, as well as the BRAND name of the alarm
system (it can't possibly be a HONDA OEM alarm).
Tell the dealer to give you ALL your money back, and to put the Odyssey
back the way it was before they chopped up your wiring harness, and go
to another Honda dealer and have them install a HONDA alarm.
'Curly'
Old 09-21-2005 | 02:30 PM
zonie
Guest
Posts: n/a
Good advice from Curly. Im sure the alarm is some cheap aftermarket system
installed by some kid they pay 6 bucks an hour and he cut into whoknows
what wrong wires. That dealer butchered your Honda, make them fix it!
Scott
Old 09-21-2005 | 07:30 PM
toypup
Guest
Posts: n/a
"E Meyer" <epmeyer50@msn.com> wrote in message
news:BF56CD0D.DFA17%epmeyer50@msn.com...
> of
2003. It has 32000 miles, so still under warranty. Other Honda dealers
will not fix it because they immediately assume it is an alarm problem.
I just got the minivan back from maintenance yesterday. They told me they
disarmed the autoarm feature of my car alarm. The TCS and engine lights
came on. I used the winshield wiper spray and the wiper got stuck in the up
position. It came back down after some jiggling. Those problems, like all
my other problems, are intermittent. So, when I get it back to the dealer
today, the lights were off and the wiper was working. The minivan is in the
shop right now. They are checking it out once more.
Old 09-21-2005 | 09:31 PM
Gordon McGrew
Guest
Posts: n/a
>Scott
I concur. Aftermarket electronics are almost always bad. I actually
paid my mechanic about $150 to rip out every bit of electronics
installed by the previous owner. After removing about 20 pounds of
stereo and alarm crap, the stereo works better than it ever has. the
alarm never did work right since the day I bought it.
OliviaNewtonJohn
09-08-2011 05:02 PM
Blackbeard
11-08-2010 12:52 PM
teebar47
09-21-2009 12:57 PM
Darkhope
10-14-2008 10:10 PM
cph81
02-21-2008 08:48 PM
