edo-competition Porsche 997 GT2 R
I lied, here is one more... Be sure to check the wesite, because they some incredible upgrades for already extreme machines.
edo competition -HOME-
Specifications
Engine water-cooled, twin-turbocharged horizontally opposed 6-cylinder
Power est. 542 hp / (398 kW) at 6,790 rpm
Torque 755 Nm (557 ft-lb) at 4,300 rpm
Performance
Top speed 330 km/h (205 mph)
0 – 100 km/h (0 – 62 mph) 3.8 s
0 – 200 km/h (0 – 124 mph) 11.0 s
Features
The basis is formed by the edo 996 GT2 R, which had already been modified in the areas of brakes, suspension, engine, transmission, aerodynamics, exhaust system, interior, wheels/tires and light-weight windows. The only thing missing to be up-to-date is the look of the current Porsche 997!
To that end, the following conversion kit made from ultra-light carbon fiber was created:
Specifications
Performance
Features
- Complete front fascia: front skirt, radiator inlets, brake cooling ducts
- Front fenders modified and widened
- Fender liners
- Mesh inserts front and rear
- Front lip spoiler in carbon fiber
- Modified fuel filler door
- Litronic headlight kit
- Brake system - Rotor diameter front/rear 380/350 mm with 4-piston fixed calipers
- Suspension - Adjustable edo/KW sport suspension with individually adjustable
compression and rebound damping - Wheel dimensions - Tires: Michelin Pilot front 235/45-18, rear 335/30-18 on 10” and 13” wheels
Sid 6.7
08-03-2008 01:39 AM
