My Honda will not stay running/Help me
Guest
Posts: n/a
My car will not stay started,I turn the ignition lock switch to start the
car and when I let go of the key for it to go to the seating postion it
will shut off.I replaced the ignition switch but it is doing the
samething.
Please help me!!!!!!!What should I do next?????
samething.
Guest
Posts: n/a
Re: My Honda will not stay running/Help me
"FDaviDH2" <fdavidh2@aol.com> wrote in message news:0fc0befd2796b20fcd1b07aec14d03b4@localhost.ta lkaboutautos.com...
> samething.
Can you diagnose the problem? Check then supply battery voltage
to the ignition switch part that powers the ignition. If that doesn't work,
supply battery voltage to the fuel pump.
> samething.
Guest
Posts: n/a
news:0fc0befd2796b20fcd1b07aec14d03b4@localhost.ta lkaboutautos.com:
> samething.
Does it start and keep running as long as you keep the key turned to START,
but stall as soon as you let go of the key?
Main Relay.
TeGGeR®
www.tegger.com/hondafaq/
> samething.
Main Relay.
TeGGeR®
Guest
Posts: n/a
> samething.
It might be helpful to know the model, year, mileage and country you're
in. Has the vehicle been in any kind of an accident as well?
'Curly'
> samething.
'Curly'
soccerdude
09-17-2014 11:56 PM
Anastasio
07-04-2005 12:20 AM
