90 Accord fan relay/motor
Old 08-28-2005 | 08:52 PM
Pete from Boston
Guest
Posts: n/a
I'm having what seems to be a not-so-uncommon problem in my 90 Accord,
where it overheats if not moving enough. After having cooling work
done, with the accompanying pressure test coming out ok (and most of
the system now replaced in the past year and a half), I checked the
cooling fan fuse. Blown. Replaced it, turned on the car, that fuse blew
immediately. What's the likely culprit? How much should the fix cost me?
'Curly Q. Links'
Guest
Posts: n/a
Re: 90 Accord fan relay/motor
The fan motor bushings are dry (worn out probably) Try spinning the fan
by hand. Brushes might be worn to nothing and shorting too.
'Curly'
Old 08-29-2005 | 06:33 AM
B Squareman
Guest
Posts: n/a
"Pete from Boston" <masspete@my-deja.com> wrote in message news:1125269602.312107.42410@g43g2000cwa.googlegro ups.com...
If you turn on the car and the fuse blows immediately, then this could
mean a bad switch and/or relay (which can wear out your motor's
slip ring prematurely and create a short, as Curley mentioned.)
You might want to unplug the relay. If the fuse still blows then the
short is before the relay.
Marrk
09-29-2013 03:19 PM
xwikedonex
08-07-2013 10:24 PM
Trogdor!
09-17-2010 05:33 PM
willy2005
06-22-2005 02:43 PM
dispman2000@yahoo.com
05-04-2005 12:16 PM
