how do you extract original stereo system to allow new radio to be fitted?
Guest
Posts: n/a
Does anyone know how to remove the original car stereo from a honda accord
2001?
I want to change the standard cd-player for an aftermarket radio and can't
see how the original radio caomes out of the dashboard. Is there a website
with such details step by step ? There is no haynes manual for my car at
the moment.
any help would be great.
cheers Scott~
2001?
the moment.
cheers Scott~
Guest
Posts: n/a
Re: how do you extract original stereo system to allow new radio to be fitted?
> 2001?
> the moment.
> cheers Scott~
This document covers 1998-2000, so it should apply to 2001 as well:
http://www.installdr.com/InstallDocs...PDF/466053.pdf
> 2001?
> the moment.
> cheers Scott~
Guest
Posts: n/a
In article <dei5oh$f6u$1@nwrdmz02.dmz.ncs.ea.ibs-infra.bt.com>,
> 2001?
It's quite simple. Do a search in Google groups for this, in this
newsgroup, under my name.
> 2001?
Guest
Posts: n/a
Re: how do you extract original stereo system to allow new radioto be fitted?
> 2001?
> the moment.
> cheers Scott~
Hi Scott.
Is the Accord Uk spec or USA spec.
As I swap a UK spec acord radio.
Three screw over the dash pods need to be undone then the hole cover
pulls off. from around the radio and dash.
Have a look see.
Ok
Dave
> 2001?
> the moment.
> cheers Scott~
Hi Scott.
Have a look see.
Ok
Dave
Guest
Posts: n/a
On Thu, 25 Aug 2005 15:18:51 +0000 (UTC), David Haigh
<dwight1380@btinternet.com> wrote:
>> 2001?
>> the moment.
>> cheers Scott~
If your car is the same as a 2000, then this should help:
>> 2001?
>> the moment.
>> cheers Scott~
got80s
09-17-2005 04:43 PM
