94 Accord A/C not working
Guest
Posts: n/a
Re: 94 Accord A/C not working
"cmilner2" <cmilner@hotmail.com> wrote in message
news:c035589f2b296b6252857a0daed46304@localhost.ta lkaboutautos.com...
> My 94 Accord A/C will not work. The compressor kicks on, and I've checked
> the freeon (spelling?) level and it's high. Any suggestions for things to
> check other than the compressor and freeon?
> Thanks
Checking that the compressor clutch is spinning and freon is present a good
first step. Without knowing more, my guess is that your compressor is no
longer "compressing" properly - you should have a pressure difference
between the 'High' and 'Low' side of the system. Take it to a Tune Up shop
that handles A/C and have it checked. You should be able to find a shop
that will check the pressure for a "special price" of $20-30. My guess is
that the pressure differential will turn out to be virtually zero. If that
is the case, expect to have to replace the compressor, evaporator and
condenser... Mechanics charge $1200+ easy for parts and labor.
Guest
Posts: n/a
> Thanks
Freon pressure HIGH is just as bad as LOW . . It will shut the system
OFF. There's a safety switch for BOTH conditions.
'Curly'
Guest
Posts: n/a
> > Thanks
> 'Curly'
And in case you don't find two switches, Honda often uses a single
switch that will trip at both too high and too low pressure.
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
Frank Boettcher
06-18-2005 10:17 AM
