How do I find (and fix) problem with main relay on 91 Accord??
Guest
Posts: n/a
When its hot out, my 91 Accord will not start. The check engine light will
stay on. After banging on the dash and letting it sit for a while I turn the
key and I hear the fuel pump kick in (which it didnt before letting it sit)
and it will start on the first crank. I have heard from a couple of people
that this is a common problem for this model 90-93. They said to resolder
the main relay. Where is the main relay located and how do I fix this
problem? Will resoldering the connection fix this?
Message posted via CarKB.com
http://www.carkb.com/Uwe/Forums.aspx...-cars/200508/1
Guest
Posts: n/a
Re: How do I find (and fix) problem with main relay on 91 Accord??
"Spoilaz via CarKB.com" <forum@CarKB.com> wrote in message
news:529ACFE41071E@CarKB.com...
will
the
sit)
people
It should be near your left knee, under the panel. You can often see them by
looking up into your dash. This site has a very good description:
http://www.tegger.com/hondafaq/start...html#mainrelay
will
the
sit)
people
Guest
Posts: n/a
I looked at the site that you recomended and it seems pretty cut and dry.
When I get home from work tonight I will take a look under the dash and see
if I can fix it. Thank you very much for the info and I will post the
results soon. :)
results soon. :)
Guest
Posts: n/a
> results soon. :)
Actually, we already know what the results will be. The solution is
always the same, and if you do it properly, you won't be back for 10
more years. :-)
'Curly'
> results soon. :)
more years. :-)
'Curly'
isabelaneric
06-29-2005 10:39 AM
punkyw
05-15-2005 07:30 PM
