96 accord cooling fan
Old 08-06-2005 | 05:43 PM
Dukes88
Guest
Posts: n/a
secondary cooling fan doesn't run anymore...Overheats during stop and go
traffic...any Ideas?
Old 08-06-2005 | 07:45 PM
remco
Guest
Posts: n/a
Re: 96 accord cooling fan
"Dukes88" <billetdeaux88@yahoo.com> wrote in message
news:761219f3b0b5a516c486bfe268c0ef13@localhost.ta lkaboutautos.com...
Check http://www.tegger.com/hondafaq/overh...dex.html#nofan
Remco
Old 08-07-2005 | 01:31 AM
R. P.
Guest
Posts: n/a
Unfortunately that web page does not display right even in IE Ver. 6
SP2. It's full with "if" and "endif" source lines.
Rudy
Old 08-07-2005 | 10:30 AM
remco
Guest
Posts: n/a
"R. P." <r_pol12gar@hotmail.com> wrote in message
news:u7Kdneb_bfHgG2jfRVn-jA@comcast.com...
> Rudy
Yeah, I noticed that too just now - it was designed for IE6 and worked fine.
Wonder what's going on with that page..
Old 08-07-2005 | 08:32 PM
Sam Nickaby
Guest
Posts: n/a
To web developers. Avoid using MSWord to create Webpages. They
aren't cross-browser compatible - can't even display on its own MS
browser. Here's a screen shot of the errors.
http://www.yourimg.com/?img=05/219/17/msword.gif
A quick Google search I find a place to design and copy and paste the
standardized source code into your site.
http://www.editlet.com/testdrive/dhtml/dhtml_test.htm#
Scroll down and click on Edit An Existing Web Page.
Frank Boettcher
Guest
Posts: n/a
On Sat, 06 Aug 2005 15:59:13 -0400, "Dukes88"
disconnect the fan then jump it directly to the battery. If it
doesn't turn your fan motor is cooked. If it is the radiator fan you
can get a motor for about $50. If it is a AC condensor fan I have
only been able to find a complete assembly about $120. Probably what
is wrong is the brushes are worn out, but I have yet to find any
replacements.
If it does turn you probably have a thermo/relay that is bad.
Old 08-08-2005 | 07:52 PM
Bruce
Guest
Posts: n/a
I just went through the same problem on my 90 civic ex. I read in
several threads that the motors are extremely robust and hardly ever
fail... stupidly I didn't test it before buying a new thermo switch.
Replaced the switch for $50 (and a face-full of coolant taking it out)
and fan STILL didn't work. Just ordered a replacement motor for $43.
Grrrrrrr....
Now I'll get the motor and the relay will be bad... as the saying goes,
If I didn't have bad luck I'd have no luck at all.
dazeddriver
09-06-2005 08:31 AM
Todd K.
08-02-2005 12:52 AM
TeGGeR®
07-07-2005 02:26 AM
Frank
05-04-2005 12:16 PM
Chris
05-04-2005 12:16 PM
