a/c high & low pressures?
Guest
Posts: n/a
I have to repalce my compressor on a 94 civic 1.5L and the shop manual does
not appear to give the high and low pressures - it jsut refers to max 19 oz
of r134. What should my guages read when properly vacuumed and and
refilled?
refilled?
Guest
Posts: n/a
Re: a/c high & low pressures?
On Thu, 28 Jul 2005 23:01:55 -0400, "Rocky"
>refilled?
depends on ambient temperature, it's different everywhere. and did
you get it down to a 400 micron vaccuum?
Chip
>refilled?
Chip
Guest
Posts: n/a
>refilled?
It depends on ambient temperature and humidity, these things aren't
set in stone!
Chip
>refilled?
set in stone!
Chip
Guest
Posts: n/a
I ended up taking the car to the gas station to have the a/c fixed - I
didn't have the time to work on it - too many late night at the office.
They said I was right, the compressor clutch failed, but the system did have
pressure. They swapped in the unit I bought from the junk year that has a 1
year warrantty on it.
The problem with the horn was a corroded wire between the relay and the
horn.
"Rocky" <jcadellano.spam@optonline.net> wrote in message
news:B_gGe.1569$7Q1.1223@fe09.lga...
>oz of r134. What should my guages read when properly vacuumed and and
>refilled?
horn.
>refilled?
Guest
Posts: n/a
Professor wrote:
> Humidity has nothing to do with system pressures...
> Professor
> www.telstar-electronics.com
I am not about to enter into a thermodynamic argument, but the factory
service manual has graphs showing system pressures as dependent on both
temperature and relative humidity. So, to the OP, go to
http://www.helminc.com and get the factory manual. It will have the
answer!
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
BigBrew
06-04-2005 11:09 PM
