1999 CRV: Keeping clock bright when lites are on?
Guest
Posts: n/a
I drive with my headlights on during the day (the '99 does not come with
DTRL), but the clock dims out when the lights go on, because there was
an assumption that lights only go on at night.
Is there a configuration somewhere within the CRV that allows for
"allways bright" on the clock?
If not, is there a wire that I can cut or short to make it always
bright? I'm assuming that at the very least there would be something on
the clock itself. Maybe 3 wires?----[ground, low, high] or maybe
[ground, Positive, lites-on] ?
Thanks!
PS. Before I thought to ask the question if there was another way, I
had asked here how to remove the clock. That damn thing is impossible
to remove! Stubborn little sucker----if you have any hints about that
too, I'd appreciate it.
Having a dog that is a purebred does not qualify it for breeding. Dogs
need to have several generations of clearances for various illnesses
before being bred. If you are breeding dogs without taking care as to
the genetic quality of the dog (again, being purebred is not enough),
you are what is known as a "backyard breeder" and are part of the
problem. Most of the congenital problems of present day dogs are
traceable directly to backyard breeding. Spay or neuter your pet
responsibly, and don't just think that you're somehow the exception and
can breed a dog without taking the care described.
Guest
Posts: n/a
Re: 1999 CRV: Keeping clock bright when lites are on?
In article <b4BCe.2966$Zx3.233@trndny05>,
"Thomas G. Marshall"
> bright?
You talk about the clock, but you forget that the clock is part of the
instrument lighting overall.
On some cars, the dashboard light dimmer switch has a position whereby
it turns all the dash lights on full strength, plenty bright for anytime.
> bright?
Guest
Posts: n/a
Elmo P. Shagnasty coughed up:
>> with DTRL), but the clock dims out when the lights go on, because
>> there was an assumption that lights only go on at night.
>> bright?
No I didn't. The clock is /not/ part of the instrument lighting. It is
under separate control, high and low based only on whether or not the lights
are on, and is not affected by the dashboard light dimmer.
> anytime.
It's time for everyone to just step back, take a deep breath, relax,
and stop throwing hissy fits over crossposting.
>> bright?
> anytime.
Guest
Posts: n/a
In article <EfFCe.4425$ij3.3951@trndny06>,
Man, Honda is making things CHEAP. I guess that's their philosophy on
the Civic-based line.
More and more, it's obvious that the beancounters are in charge at
Honda, and that engineers are way down the ladder.
Damn shame.
Damn shame.
Guest
Posts: n/a
On Sun, 17 Jul 2005 23:31:07 -0400, "Elmo P. Shagnasty"
>Damn shame.
Our Accord does that, except that there are other things that dim when
the headlights come on. I can leave it on daylight only (doesn't
matter if the headlights are on or off) by turning the odometer reset
knob. Found that by accident. I suppose if I had read the book it
would have explained it. :-)
Dick
>Damn shame.
Dick
Guest
Posts: n/a
>>Damn shame.
>Dick
I think OP said that the dimmer rheostat doesn't affect his clock
lighting. That's why he's asking here if there's a way to keep it
fully illuminated with the headlights on.
There are ways to install DTRLs which means feeding a reduced voltage
to the high beam lamps all the time, but it's expensive and
complicated (for an amateur). I investigated it, and it most
definitely is not a job for the likes of me. I'd have to have it done
by a pro, and I think that parts and labor would run the price up to
several hundred dollars. That's the only way I've discovered to
overcome the problem with dash illumination in American Accords. I'd
call the Canadians lucky, but have you ever been there in the
winter?!? It's foolish of Honda America not to make DTRLs a standard
or, at the very least, an optional feature.
I'd love to hear the regular contributors weigh in on this question.
Ron
>>Damn shame.
>Dick
Ron
Guest
Posts: n/a
On Mon, 18 Jul 2005 16:43:00 GMT, Milleron
>>>Damn shame.
>>Dick
>Ron
I was not talking about a dimmer rheostat. I was talking about a
switch that is connected to the odometer reset knob. It gives you the
option of having the clock dim with the headlamps or not. I was
suggesting this so that the OP could see if his CRV perhaps had the
same kind of switch.
Dick
>>>Damn shame.
>>Dick
>Ron
Dick
Guest
Posts: n/a
>> the lights are on, and is not affected by the dashboard light dimmer.
> Damn shame.
I'm not sure that it /should/ be part of the dash dimmer. It has differing
requirements. It needs to be on both when the headlights are on and off,
and they need to be brightest during the day, and dimmed at night. At least
that would be the theory.
"So I just, uh... I just cut them up like regular chickens?"
"Sure, just cut them up like regular chickens."
> Damn shame.
Guest
Posts: n/a
Dick coughed up:
>>>>> dimmer.
>>>> philosophy on the Civic-based line.
>>>> Damn shame.
>>> when the headlights come on. I can leave it on daylight only
>>> (doesn't matter if the headlights are on or off) by turning the
>>> odometer reset knob. Found that by accident. I suppose if I had
>>> read the book it would have explained it. :-)
>>> Dick
>> Ron
You got my hopes up. The odometer reset does not turn. :( Nor (just to be
clear) does the illumination dial do anything other than ramp up and down
the dash lights sans clock.
http://www.allexperts.com is a nifty way to get an answer to just about
/anything/.
>>>>> dimmer.
>>>> Damn shame.
>>> Dick
>> Ron
/anything/.
Guest
Posts: n/a
Milleron coughed up:
>>>> dimmer.
>>> Damn shame.
>> Dick
Hmmmm..... In my circles, this kind of thing in computing hardware (and
consumer electronics) almost always means that there's a configuration
/somewhere/ , even if it is purely unintentionally and accidentally left in
for the american models, that can be tweaked, turned on/off, or shorted.
> Ron
/anything/.
>>>> dimmer.
>>> Damn shame.
>> Dick
> Ron
/anything/.
Guest
Posts: n/a
On Mon, 18 Jul 2005 23:28:08 GMT, "Thomas G. Marshall"
>Dick coughed up:
It was worth a try anyway.
>Dick coughed up:
Guest
Posts: n/a
>>>>Damn shame.
>>>Dick
>>Ron
>Dick
Thanks. I stand corrected. Can't wait to see if my car has what
you're talking about.
Ron
>>>>Damn shame.
>>>Dick
>>Ron
>Dick
Ron
Guest
Posts: n/a
Here's the 'long' answer:
Four wires run the clock. Yellow = ACC power, White / blue tracer = On
all the time, Black is chassis ground, and Red / Black tracer is
ILLUMINATION input.
When the ILLUMINATION input is zero, the backlight runs at 100%. Apply
any voltage from the dash lights, and it drops to 50% , then down to
maybe 5% depending on the position of the brightness control. To solve
your problem, install a switch in the Red/Black line to prevent the
clock knowing the dash lights have come on. You could mount the switch
on one of the the two blank plugs to the left of the steering wheel, or
even get a matching used Honda switch from a cruise control or fog lamps.
'Curly'
ILLUMINATION input.
'Curly'
Hondafrk
07-08-2012 02:57 AM
Thomas G. Marshall
07-18-2005 08:37 PM
