1997 Civic LX Compression
Guest
Posts: n/a
Hi,
I had my mechanic check the compression on a 1997 Civic LX, he said
it's fine. when I picked up the car, I got the printed results: all 4
cylinders 160 psi (give or take 1 psi). The mechanic wasn't there, and
the cashier didn't know the spec values. From the message the mechanic
left on my voicemail I understand it''s OK, but I was just wondering
what those values should be for a good 1997 Civic LX Engine (i.e. when
it was new, and for a well taken care of engine).
Thanks
Thanks
Guest
Posts: n/a
Re: 1997 Civic LX Compression
160PSI is a very good reading... I would think new wouldn't be much
higher. Don't think you have any problems there.
Professor
Check out FlashAlert at www.telstar-electronics.com
chibitul wrote:
> Hi,
> Thanks
Professor
chibitul wrote:
> Hi,
> Thanks
Guest
Posts: n/a
chibitul wrote:
> Hi,
> Thanks
why do you care? a lot of manufacturers don't even specify a
compression reading because it's too hard to get consistent numbers.
all the compression test is good for is measuring /relative/ differences
between cylinders as per a head gasket or burnt valve problem.
bottom line, you're lucky you have an honest mechanic. unscrupulous
ones would take your desire for such a test as an opportunity to
diagnose an "imminent problem" and relieve you of several thousand
dollars for a rebuild.
> Hi,
> Thanks
Guest
Posts: n/a
jim beam wrote:
> chibitul wrote:
>> Hi,
>> Thanks
> compression reading because it's too hard to get consistent numbers. all
oh, lemme go out to the garage and check...
184 psi nominal
135 minimum
no more than 28psi difference between cylinders.
isnt the internet great?
> chibitul wrote:
>> Hi,
>> Thanks
184 psi nominal
135 minimum
chibitul
07-16-2005 02:38 PM
