Timing belt - mileage vs time
#41
Guest
Posts: n/a
Re: Timing belt - mileage vs time
Well Peabody, I'd say if Mr.Earl will pay for the collateral damage, to
the engine, if the timing belt does break before 90k. Then I'd say
let-R-run and see who's right.
Thermal (heat) cycles and proper tension also factor in on the equation
of "when to replace the t/belt."
For the record, I replaced the T/Belt on my '90 Integra 3 years ago; it
only had 68k miles. The belt didn't look particularly distressed; but
at 12 years old the car is hardly worth what it would take to
rehabilitate the engine/head if the T/Belt did break...
Peabody wrote:
> For what it may be worth:
> I have a 94 Accord (soon to be 11 years old) with only 49,000 miles
> on it. Today I went to see Earl, who for the last 15 years has run
> a local repair shop specializing in Hondas and Acuras, and who is
> highly respected for the quality of his work and his expertise.
> Earl said the timing belt is almost exclusively a mileage item, and
> he would not recommend replacing mine until I reach 90k miles,
> pretty much no matter how long that takes. He said failures at
> fewer miles are extremely rare, and he routinely sees low-mileage
> early 80's Accords which still have their original timing belts.
> Earl had the opportunity to relieve me of several hundred dollars,
> since I went in to schedule the belt replacement, but he pretty
> firmly turned me down. So, I assume he at least believes what he's
> saying, even if he may not be right.
Tp,
-------- __o
----- -\<. -------- __o
No Lawsuit Ever Fixed A Moron...
Tp,
-------- __o
#42
Guest
Posts: n/a
Tp,
-------- __o
Tp,
-------- __o
#43
Guest
Posts: n/a
slim wrote:
> Sparky Spartacus wrote:
>>slim wrote:
>>>Elle wrote:
>>>>"Peabody" <waybackKILLSPAM44@yahoo.com> wrote
>>>>E wrote
>>>>>Well, I first inspected mine at about 32,000 miles when the
>>>>>dealership "inspected" mine and told me they needed to be
>>>>>replaced. They did this with a straight face. I took the
>>>>>wheels off and looked, and it was obvious I was being
>>>>>bullshitted, and I complained to the service manager. The
>>>>>second time was last week. At 49,300 miles, I thought it
>>>>>probably wasn't too early to check them again.
>>>>My 91 Civic's first brake pads wore to the warning tabs after 43k miles.
>>>The Scumbags at Paragon Honda in LIC told me at 12K that "they had to"
>>>replace my pads to keep my warranty intact.
>>I hope you reported them to Honda.
> "Each dealership is independently owned and operated
True, but a Honda dealership is a license to print money and Honda
probably cares about how the public regards it. Dealers cannot afford to
jeopardize their relationship with Honda.
> and the repair fell into accepted standards."
Which standards are those? If the pads weren't worn to their service
life, this was fraud, along with false claim about being required to
keep the "warranty intact".
If it were me, I'd report them to Honda (plus the BBB & the state agency
which deals with this sort of thing) and see what Honda had to say,
after telling the dealer to get stuffed. Be sure to note which service
adviser told you this.
#44
Guest
Posts: n/a
"slim" <pickin's@nyc.rr.com> wrote in message
news:42D9E504.1F710861@nyc.rr.com...
> Just like when the SCUMBAGS tell you they HAVE to charge
> you four hours labor for a two hour job.
If a new mechanic took six hours, would you have a problem paying that six
hour charge?
If the experienced mechanic, with a huge personal investment in the proper
tools, does it in two hours, why should he be paid less?
Because he's better?
Same result, same charge.
#45
Guest
Posts: n/a
> hour charge?
Sure with one of the publishers I work for felt this way... will NEVER
happen!
> hour charge?
happen!
#46
Guest
Posts: n/a
In article <42DAFD56.50EDDB23@nyc.rr.com>, slim <pickin's@nyc.rr.com>
> > hour charge?
> Nice attempt at a strawman.
no, it's the truth.
> > hour charge?
no, it's the truth.
#47
Guest
Posts: n/a
news:42DAFD56.50EDDB23@nyc.rr.com...
>> six
>> hour charge?
Thanks! Enjoyed your rebuttal as well!
>> proper
> Not true.
Ok, so what's the difference between the two jobs above?
> The Scumbag says he "has" to charge $675 for a belt/pump job.
> Most mechanics around me will do the job for $400-475.
So what's the problem? Didn't shop around?
#48
Guest
Posts: n/a
>>>hour charge?
> no, it's the truth.
book rate is book rate. obviously it can be fudged by a "nice"
independant. thats why good, quick ASE certified mechanics can make good
money- by doing more work.
FWIW, when i got the engine on my rabbit convertible replaced years ago,
i had to upsell the independant mechanic by ASKING him to do the CV joints.
>>>hour charge?
> no, it's the truth.
#49
Guest
Posts: n/a
> hour charge?
Three words, Steve: flat rate manual
It won't take the new mechanic 6 hours to do a job the FRM rates at 4 hours.
> hour charge?
#50
Guest
Posts: n/a
"Sparky Spartacus" <Sparky@universalexports.org> wrote in message
news:xeICe.146551$mx5.103373@fe08.lga...
>> six hour charge?
>> proper tools, does it in two hours, why should he be paid less?
> hours.
*sigh*
Never mind.
#51
Guest
Posts: n/a
jim beam wrote:
> i've spent a whole lot of time in junk yards over the years [a great
> place to see a lot of failures] and gotta say, it's pretty unusual to
> see a [honda] timing belt that's in such bad condition that i'd be
> concerned about failure just through age. theoretically, yes, belts
> crack, belt fibers fatigue and teeth fall off, but this is seldom
> without any form of visible deterioration. i say, do a visual
> inspection. if it apears to be in bad shape, cracking, fraying, teeth
> worn or deformed, yes, replace regardless of mileage. but if it's not,
> and you /know/ for sure mileage is within spec, i'd stick with earl's
> advice.
How do I inspect the TB? It appears to be under a cover that's between
the water pump and the engine?
Some info FWIW:
90 Civic (bought new 2/90); 116k miles, original timing belt and water
pump.
(previous Usenet research indicated engine damage from a break
was relatively rare? Anybody got real data on this?)
~8k miles/year, 1500 highway, rest 4 miles/day to work.
Recent problems:
Transmission made a grinding noise while in neutral/park, did it 3
times then stopped - loose/broken parking pawl?
Minor oil leak - a few drips a day.
Mild "rubbing" noise from left front wheel; goes away when brakes
applied. CV joints replaced with rebuilts a few years ago.
Same "hot engine after stopping" as reported in another thread - did it
once after a few hours of highway driving, hasn't done it since.
Latest problem:
Wouldn't start Sunday noon - turned over, but no ignition.
Left it, had a friend check it Monday morning, said it fired right up.
Went back after work with him, and it wouldn't start again :^(
Popped air hose in front of injector in case air filter was clogged
(bolts are rusted thus can't check it); didn't seem to help.
Let it sit for 5-10 minutes, gave it one last try before giving up and
having it towed to dealer, and it fired up - ???
Is it the fuel pump/filter, the timing belt, or something else?
On my 81 Civic once I had a vacuum line come off; it would stall, and
not start unless I took the air cleaner cover off and waited a few
minutes.
I really like this hatchback, and until Honda starts making them again,
I'd rather not have to replace my 90; but I also need to have the body
bondo-ed every year to get through PA inspection, and that's starting
to get old too :^(
My dealer recently moved off the bus line, and they've never been big
on loaners, so I generally have to be desperate to take it to them :^(
Ron Bauerle
> advice.
Some info FWIW:
pump.
Recent problems:
Latest problem:
minutes.
to get old too :^(
Ron Bauerle
#52
Guest
Posts: n/a
>>advice.
take the valve cover off and you can remove the top part of the belt
cover easily.
> Some info FWIW:
> pump.
"relatively rare" is too hard to quantify. probability of failure
increases with mileage.
> Recent problems:
main relay
> Latest problem:
main relay
main relay
> minutes.
> to get old too :^(
i'm with you on the hatchback thing. let's all write to honda usa &
tell them we want our hatchbacks back!
> Ron Bauerle
>>advice.
cover easily.
> Some info FWIW:
> pump.
> Recent problems:
main relay
> Latest problem:
main relay
main relay
> minutes.
> to get old too :^(
> Ron Bauerle
#53
Guest
Posts: n/a
> >> six
> >> hour charge?
> >> proper
> > Not true.
I got mine done for $400 by a mechanic who does a lot of Hondas.
http://www.usatoday.com/news/world/i...now-usat_x.htm
"Other top officials, including Cheney and Rumsfeld, said the war would
last
"weeks, not months.""
http://www.natcath.com/NCR_Online/ar...05/052705w.php
"More than two years into a war that was supposed to be quick and easy,
and
the justification for which has spun from removing a dictator to
eliminating
weapons of mass destruction to fighting terrorism and, finally, to
planting
democracy that would then spread across the Middle East, Iraq is in chaos."
RayGun sends his lackey to kiss Saddam's ass.
http://www.worldmessenger.20m.com/weapons.html#wms
http://www.bushflash.com/thanks.html
WHY IRAQ?: http://www.angelfire.com/creep/gwbush/remindus.html
http://www.quantumphilosophy.net/fil...yan_Medium.mov
http://www.toostupidtobepresident.co...ickenhawks.htm
"Bubba got a BJ, BU$H screwed us all!" - Slim
#54
Guest
Posts: n/a
news:42DD1B19.DECEDEAD@nyc.rr.com...
Well, that's clear.
Thanks for playing.
#55
Guest
Posts: n/a
news:42DD1AEC.BC8CBB56@nyc.rr.com...
>> > > that six
>> > > hour charge?
>> no, it's the truth.
> What dealer would hire (and keep) a wrench who does a two hour job in six?
> Strawman....burned.
You work hourly, don't you....
sorensong@gmail.com
05-04-2005 11:16 AM
