honda civic tune up trouble
Old 07-10-2005 | 04:50 AM
TeGGeR®
Guest
Posts: n/a
Re: honda civic tune up trouble
"BADMOJO" <jlkellum3@nctv.com> wrote in
news:97357ed5b4ada2876eab27a6668e927f@localhost.ta lkaboutautos.com:
> i recently performed a minor tune up including spark plugs air filter
> fuel filter and throttle body cleaning with finger tips and carb
> spray. upon completion of the job, i tried to start the vehicle. no
> dice. checked fuel pressure good, air supply as good as it has ever
> been. no spark. what did i un wittingly mess up when i was tuning. i
> tried the original plugs. no fire. i checked the relay, three clicks
> as it should have. it has 140,000 miles on it and was running pretty
> good until i tuned vehicle. please help.
You replaced the fuel filter. Turn the ignition key to II (NOT to "start").
Wait for the Check Engine light to go off. Now do this ten more times or
so.
Still no start?
Do you have the plug wires the right way around?
Did you plug in all the hoses that were attached to the intake hose?
TeGGeR®
www.tegger.com/hondafaq/
BADMOJO
Guest
Posts: n/a
i recently performed a minor tune up including spark plugs air filter fuel
filter and throttle body cleaning with finger tips and carb spray. upon
completion of the job, i tried to start the vehicle. no dice. checked fuel
pressure good, air supply as good as it has ever been. no spark. what did i
un wittingly mess up when i was tuning. i tried the original plugs. no
fire. i checked the relay, three clicks as it should have. it has 140,000
miles on it and was running pretty good until i tuned vehicle. please
help.
Old 07-10-2005 | 09:41 AM
duckbill
Guest
Posts: n/a
I had a similar thing happen to me after doing a valve adjustment on my 95
Civic Ex. Because I did not ground the coil's high voltage lead when I
bumped the starter, I fried my coil. I have learned my lesson here.
Either ground the high voltage side on your coil or disconnect the input
to the coil before turning the motor over with the coil disconnected for
maint. purposes. I was also told by two different dealerships that
Honda's sometimes lose their ignitor and coil at the same time, but I
would check the coil first. Good luck.
Old 07-10-2005 | 01:33 PM
jim beam
Guest
Posts: n/a
duckbill wrote:
<snip>
not likely - that's just dealers with their "we've got it open, let's
replace everything" policy. makes sense for them 'cos they don't want
returns. makes no sense for you if you're doing the work yourself.
Old 07-10-2005 | 04:39 PM
BADMOJO
Guest
Posts: n/a
i originaly spun the engine over a couple of times without the throttle
body hose hooked up in order to clean the throttle body. i have the plug
wires in the correct order and i have fuel pressure to the fuel rail as is
apparent by loosening the bolt on it to bleed the line and it about
showered me with fuel. I am about 98 percent positive that i have no fire.
i have done all but hold the plug while it is spinning over to test it. i
just dont understand why i lost fire when i simply removed the plugs. i
believe that it is cursed.
BADMOJO
Guest
Posts: n/a
is there any way to check the ignitor/ coil with a test light. which wires
should i probe. is the ignitor the little black bar in the dist with the
contact that brushes the rotor button or is it the piece that has the
wires plugged into it? the inside of the dist cap was relatively clean for
the mileage with only slight oxidation on the contacts. i cleaned all of
them, still no fire. its a conspiracy i believe.
Old 07-10-2005 | 07:19 PM
duckbill
Guest
Posts: n/a
Your can't check the coil (most likely problem) with a test light. You
need an Ohms meter to check resistance and continuity. Almost anyone with
a meter should be able to check it. An Advance / AutoZone store might
check it for free. You need the specs on the coil. Do you have them?
Old 07-10-2005 | 10:16 PM
jim beam
Guest
Posts: n/a
the ohm meter test only tells you if the coil's burnt right out - it
can't reliably test the coil for operation - the winding may be perfect
and test perfect, but if the internal insulation has broken down, it may
be conducting at say 5kV, not holding to 40kV like a good coil. if it
breaks down at 5kV, you'll never spark a plug with it.
to test, you need an old plug [with the outer electrode gapped /huge/]
and some leads to connect up the lug to the coil & battery. disconnect
all other leads.
Old 07-10-2005 | 10:58 PM
duckbill
Guest
Posts: n/a
BADMOJO I'm not sure what year your Civic is but the Honda Factory Service
Manual for the 95 Civic tells you to check your coil with an ohmeter. As
follows:
primary winding 0.6 to .08 ohms........secondary winding resistance 12.8
to 19.2 thousand ohms. The ohmeter will tell you if the coil is shorted or
open (burnt out). You might consider purchasing a Hayes Repair Manual for
around $15 or check one out from the library. That will help make things
very clear.
Good Luck
Old 07-11-2005 | 01:05 AM
Gordon McGrew
Guest
Posts: n/a
On Sun, 10 Jul 2005 09:21:53 -0700, jim beam <nospam@example.net>
wrote:
>duckbill wrote:
><snip>
My independent mechanic couldn't solve the so start condition on my
'94 GS-R. Wouldn't start after replacing the ignitor. He finally
called a mechanic friend at the Honda dealership who told him to
replace the coil also. He said that a bad coil damages the ignitor.
Old 07-11-2005 | 10:18 AM
TeGGeR®
Guest
Posts: n/a
news:587224908d1c89a280131a9e5b019a76@localhost.ta lkaboutautos.com:
> throttle body hose hooked up in order to clean the throttle body.
How did you prevent the engine from starting when you "spun" it over?
TeGGeR®
Old 07-11-2005 | 10:31 AM
BADMOJO
Guest
Posts: n/a
plug wires not connected at that time
BADMOJO
Guest
Posts: n/a
thanks i believe that i will have to try that
BADMOJO
Guest
Posts: n/a
yes another fellow listed the primary and secondary winding resistance
numbers
BADMOJO
Guest
Posts: n/a
numbers
BADMOJO
Guest
Posts: n/a
looks like ill be replacing the coil and ignitor. it would probably be
cheaper to just replace the distributor would it not?
Old 07-11-2005 | 11:36 AM
TeGGeR®
Guest
Posts: n/a
news:a709cec56cd1b84a0315391353eca33b@localhost.ta lkaboutautos.com:
Oops! You wrecked your coil.
Replace it.
http://www.tegger.com/hondafaq/startproblems.html#fail
TeGGeR®
Old 07-11-2005 | 02:58 PM
BADMOJO
Guest
Posts: n/a
Ok that is what i was afraid of. we will try that
Old 07-11-2005 | 11:36 PM
BADMOJO
Guest
Posts: n/a
refresh my education. when testing with the ohm meter i ohm out from coil
lead to positive or from pos to neg. or in what order? it seems to be
reading impedence in the aforementioned ranges. if the coil reads
correctly what then? thanks mojo
Old 07-12-2005 | 01:11 AM
jim beam
Guest
Posts: n/a
+ & - for primary, ht lead to either for the secondary - if you have
them in series, you'll never know because the secondary's resistance is
so high in comparison.
