99 Civic LX won't start (sometimes)
Guest
Posts: n/a
I've encountered a problem where my 99 Civic LX will not want to start
on occasion.
This is what happens:
1. Key in ignition turned 1 step and fuel pump completes cycle
2. Turn Key full rotation to start...
3. Nothing happens.... There is only an audible click but the starter
does not crank.
After several tries (inconsistent on the number of attempts required),
eventually the starter kicks in and cranks the engine. Infrequently,
the starter will attempt to crank but just chokes and the engine does
not start. I have just replaced the battery, but that has not solved
the problem.
Any advice on troubleshooting the problem is appreciated.
Could this be a sign of a dead starter? (I've never had one go on a
Honda!)
Thanks,
on occasion.
does not crank.
the problem.
Honda!)
Thanks,
Guest
Posts: n/a
Re: 99 Civic LX won't start (sometimes)
> on occasion.
> does not crank.
> the problem.
> Honda!)
> Thanks,
Since you already changed the battery, you've probably eliminated loose
battery clamps (but check them again anyhow), so go to the other end of
both of your battery cables and check for looseness / corrosion. Have
you checked with the dealer to see if your ignition switch was part of
the 'great campain'??
'Curly'
> on occasion.
> does not crank.
> the problem.
> Honda!)
> Thanks,
'Curly'
Guest
Posts: n/a
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in
news:42B3A0BF.7060408@interbaun.com:
>> Honda!)
http://www.tegger.com/hondafaq/tsb/civic/x02-031e.pdf
I see the OP appears to be around Hamilton, Ontario. This raises the
question of corrosion. Check all grounds, especially the battery ground
cable and the engine ground cables. Also check the battery live cable that
goes to the starter. Has the car ever been in a serious collision?
TeGGeR®
>> Honda!)
TeGGeR®
Guest
Posts: n/a
> Honda!)
does the ignition switch recall apply to your model? if so, has it been
done?
> Honda!)
done?
Guest
Posts: n/a
<sstula@hotmail.com> wrote in message
news:1119061602.148824.38930@o13g2000cwo.googlegro ups.com...
> on occasion.
> does not crank.
> the problem.
> Honda!)
> Thanks,
Had the same problem with an 01 Prelude. It was the ignition switch -- a
$25.00 repair.
Guest
Posts: n/a
I replaced the starter today. Luckily, a friend had a spare. We'll see
how it goes. So far so good, no problems today. Should it continue,
I'll tackle the ignition switch as my car is on the recall list for
this item.
this item.
mmdir2002@yahoo.co.uk
05-04-2005 11:16 AM
nospam_alan@yahoo.co.uk
05-04-2005 11:16 AM
