1991 Civic Stalls
Guest
Posts: n/a
1991 Civic Stalls
Hi.
My car has developed a problem that I cannot find a solution to. It is
a 1991 Honda Civic Special Edition (Canadian Model), 1.5L, 180,000kms.
It is basically a DX with power steering and no AC.
To the problem...
The car stalls. It only stalls when warm, and only when coming to a
stop. To be exact, only after coming to a stop. Sometimes it does not
stall, but almost stalls, then recovers. Sometimes is almost stalls,
then recovers and over revs, then almost stalls again. Back and Forth.
Sometimes it fixes itself, other times it stalls. Most of the time,
it immediately settles down to idle as it should, but at least once per
trip it will act up. It will sometimes stall with a gentle throttle
blip at idle as well.
The problem first started occurring when I had to back the car down a
hill into my driveway. The problem continues and seems to get slightly
worse all the time.
The car always starts immediately after a stall. The check engine
light is not on, and the ECU is not showing any codes. I have cleaned
the injectors, replaced plugs, rotor, cap, fuel and air filter. Every
time I do something nice for the car, it behaves for about one tank of
gas, then it acts up again. It happens when it is hot out, and when it
is cold, on summer gas and on winter gas, full tank and empty tank. On
high octane and low octane. Even though it happens regularly, I cannot
force the event to occur.
The dealer says they cannot do anything unless it stalls for them.
Does anyone have any idea what might be the cause of this? With this
exception, the car feels great and the engine is strong.
I appreciate any help or suggestions.
Thanks.
-Paul
To the problem...
worse all the time.
Thanks.
-Paul
Guest
Posts: n/a
Re: 1991 Civic Stalls
Paul wrote:
> Hi.
> To the problem...
> worse all the time.
> Thanks.
> -Paul
if it's a function of braking, check the one-way valve on the brake
servo or the vacuum line for leaks.
> Hi.
> To the problem...
> worse all the time.
> Thanks.
> -Paul
Guest
Posts: n/a
My Civic also stall. First during the warming up, the RPM surge then
hesitate all the time, then settle down. During the stoping at stop
sign, sometimes I feel the tiny bit
of staling l, not the major install. It's so tiny stalling that I just
ignore. I've seen many
stall problem on Honda that i think it's just normal as long it does
not effect on
driving. My stalling hardly effect on driving.
Guest
Posts: n/a
If you determine it's not the brake assist check valve, get a cheap
diagnostic fuel pressure gauge (compatible with fuel injection
pressures - not the 6-10 psi gauge) and tape it to the windshield. If
the fuel pressure dips when you slam on the brakes, it could be
something in the fuel tank (pump pickup, etc).
Guest
Posts: n/a
"Paul" <sidlickp@yahoo.ca> wrote in message
news:1118512993.628116.133370@g14g2000cwa.googlegr oups.com...
> Hi.
> To the problem...
> worse all the time.
> Thanks.
> -Paul
I don't know if this applies to Hondas, but if it is an automatic tranny
with a lockup torque converter that symptom can mean a bad lockup solenoid.
For that problem, in addition to stalling there is a feeling of shuddering
(instead of dying away) when coming to a stop, just like leaving the clutch
engaged too long on a manual tranny.
Otherwise, I like "scromwell2's" recommendation with a fuel pressure guage.
It would answer a range of questions.
Mike
> Hi.
> To the problem...
> worse all the time.
> Thanks.
> -Paul
Mike
Guest
Posts: n/a
Honda has the lockup solenoid on top of the tranny. Its look like two
cylinders and a filter underneath it. Take it out and has a deep clean.
Good lick
"Michael Pardee" <michaeltnull@cybertrails.com> wrote in message
news:ouGdnS-9759tVDPfRVn-sA@sedona.net...
> > Hi.
> > To the problem...
> > worse all the time.
> > Thanks.
> > -Paul
solenoid.
clutch
guage.
> Mike
Good lick
> > Hi.
> > To the problem...
> > worse all the time.
> > Thanks.
> > -Paul
solenoid.
clutch
guage.
> Mike
Bob Radley (nazarl at idirect dot com)
06-27-2005 09:22 AM
06-24-2005 12:43 AM
