AT has better MPG than MT?
Old 06-08-2005 | 10:16 AM
Guardsman
Guest
Posts: n/a
Re: AT has better MPG than MT?
>>>>> Bucky writes:
b> I was checking out the MPG, and I noticed that for the 2005 Civic EX
b> Special Edition, the AT has better highway gas mileage than the MT (38
b> vs 37). I can understand them being the same, but how can AT be higher
b> than MT? The AT even weighs 56 lbs more.
b> http://automobiles.honda.com/models/...n&Category=ALL
Top gear ratio?
http://www.hondanews.com/CatID2015?m...42203&mime=asc
EX MT: 5th gear = 0.757, final drive = 4.41
EX AT: 4th gear = 0.638, final drive = 4.36
Dave
Guest
Posts: n/a
In article <m3y89lg7ym.fsf@xanthu.home>, Guardsman <spear@net.invalid> wrote:
> Top gear ratio?
Looks like a good call to me. Guess with the torque
multiplication of an auto, and the automatic kick-down, they feel
they can get by with a taller ratio. And maybe an aggressive
lockup control algorithm which will make the auto a lot more
efficient than otherwise. Still seems unusual to best a manual on
the EPA highway drive.
dold@XReXXATXha.usenet.us.com
Guest
Posts: n/a
> Top gear ratio?
And 15" wheels instead of 14". Taller overall?
Lower city mileage, which would also fit with the "taller" idea.
My Civic Hybrid has CVT, not a four speed AT, and I can believe that it is
much more efficient at selecting engine speeds than I would be with a MT.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8,-122.5
Guest
Posts: n/a
Oops, reading sideways... AT & MT both have 15" on the EX.
TeGGeR®
Guest
Posts: n/a
dold@XReXXATXha.usenet.us.com wrote in news:d856e5$anr$1@blue.rahul.net:
>> Top gear ratio?
Unlikely. That would alter the ride height unless the suspension was made
differently, which it's surely not.
If you look at the tires, I think you'll find the height percentage will be
different between the two. The 15" wheels will have a smaller number there.
i.e.: 195/65-14 vs 195/55-15. Something like that.
TeGGeR®
www.tegger.com/hondafaq/
SoCalMike
Guest
Posts: n/a
CVTs generally are. they pick the most efficient engine speed and the
belt drive tranny ratio compensates.
Guest
Posts: n/a
Tire Diameter Tread Width
185/70R14 24.25 5.51
195/60R15 24.21 6.25
Right you are.
Bucky
Guest
Posts: n/a
Is this just a deviation error in the EPA test? Is the EPA test a
one-shot deal, or do they conduct it many times and take the
best/average? Perhaps due to slight statistical deviation, maybe AT got
37.50 and MT got 37.49. Round it to the whole number and it looks like
a big difference.
Old 06-10-2005 | 07:34 PM
Gordon McGrew
Guest
Posts: n/a
On 9 Jun 2005 19:39:35 -0700, jmattis@attglobal.net wrote:
>> > The driver of a sporty car sure doesn't want
>> > to have to downshift to 4th, to climb a little hill or do a lazy
>> > passing manuever.
>> Then he should just drive in 4th all the time.
>As a person who's not especially fond of manual transmissions, I could
>agree with you. But, in the marketplace, manufacturers will instead
>respond by selling these drivers what they want in the first place.
I wouldn't care if they would just make what I want.
Guest
Posts: n/a
Which would be, maybe a Corvette. Maybe a Viper. Maybe an I30 or
Maxima SE with a 5 speed. I haven't driven one, but I suspect even a
6-speed V6 Accord coupe might pass the test in most people's eyes.
I see what's going on here. I'm in a den full of manual transmission
mavens, and said something nice about automatics. ;^)
SoCalMike
Guest
Posts: n/a
>>>passing manuever.
which would be... what? my CX is a 5spd, and only has 108hp. 5th gear is
for freeway cruising. cool with me.
Guest
Posts: n/a
> > passing manuever.
Bucky
Guest
Posts: n/a
> passing manuever.
Guest
Posts: n/a
Bucky wrote:
> Nightdude wrote:
> > From my experience, It's the other way around. AT usually runs lower @
> > highway speeds.
> I guess I had the wrong impression. I always figured having the extra
> gear with a manual meant the lowest gear could be lower and the highest
> gear could be higher.
> I don't see why they don't make the top gear ratio in MT be equal to
> (or even smaller than) AT. The MT driver would just downshift to 4th
> before trying to accelerate at highway speeds. Isn't that the point of
> MT, so that the driver can decide what gear they want to use?
I think you have the right impression overall. But, it is not
universally applicable. The driver of a sporty car sure doesn't want
passing manuever. It's a sure sign of an econobox when you floor it in
5th and nothing happens. Even some econoboxes are designed to avoid
this.
Bucky
Guest
Posts: n/a
> highway speeds.
Nightdude
Guest
Posts: n/a
highway speeds.
"Bucky" <uw_badgers@email.com> wrote in message
news:1118258085.634256.31070@g43g2000cwa.googlegro ups.com...
> So the top gear ratios are:
> MT = 0.757 x 4.41 = 3.34
> AT = 0.638 x 4.36 = 2.78
> Does this mean that if a MT is going at 3000 rpm,
> then the AT is only going at 2497 rpm??? I thought that AT ran at
> higher rpms at highway speeds (or was that a thing of the past)?
Bucky
Guest
Posts: n/a
Guest
Posts: n/a
> than MT?
Yes, its in the gearing. My '96 Infiniti I30t automatic is rated for
28 highway. Less than 10% of those I30's were manuals, rated at 26
mpg.
4-speed Automatic: 0-60 8.2 sec
5-speed Manual: 0-60 7.5 sec
There was a car back in the early '80's that even accelerated slightly
better with a 3-speed auto than a 5-speed manual, a Ford compact I
think. Tinkering with converter stall speeds and other auto tranny
items can make them pretty effective competition.
memoryrose
06-08-2010 10:34 AM
kicks
01-28-2009 10:02 PM
monkeykevin
11-20-2008 01:05 PM
mdanderson
07-10-2007 02:42 PM
cheffyjay
05-05-2006 01:55 PM
