98 Accord LX hesitates after starting
Guest
Posts: n/a
My '98 Accord LX has been hesitating after I start it for a few months. My
check engine light was on for a while and when I had regular maint. (~85k
miles), they said it was nothing and reset it. The light came back on not
long after. Both before and after the service, the car has been hesitating
and sometimes stalling when I try to accelerate just after starting the car
(in any weather). Once I'm going, no problems. If it matters, I drive ~60
miles, all expressway (60-80 mph), every day. Thanks in advance
Guest
Posts: n/a
Re: 98 Accord LX hesitates after starting
If it runs great once it warms up, have you had anybody touching your
Timing Belt? TIt sounds like a good symptom of a timing belt being out a
tooth.
You've checked your coolant levels, etc? You need to look on your work
order and find out what the code was. Report back. Isn't your timing
belt getting close to being 'old'?
'Curly'
tooth.
'Curly'
Guest
Posts: n/a
youll need to find out what the code is its giving off, and figure out
the best way to troubleshoot and fix it. i cant really blame the dealer
for resetting it and sending you on your way, but this time around they
need to do something.
Guest
Posts: n/a
Similar systems in my 98 LX turned out to be a failing catalytic converter,
which was just on the right side of warranty coverage at the time.
"sdonn" <sldonnel@yahoo.com> wrote in message
news:ab683ccc5aedefd3655437e66a334cbc@localhost.ta lkaboutautos.com...
> car
> car
jmattis@attglobal.net
07-02-2005 09:31 AM
sdonn
06-18-2005 10:17 AM
Paul Jackson
05-04-2005 11:16 AM
