Honda Civic: oxygen sensor causes computer failure?
Guest
Posts: n/a
My son just took his01 Honda Civic in because the engine light came
on. The diagnosis was that the oxygen sensor was bad, so they
replaced it. He then gets another call saying that the sesnor was
only part of the problem. When the sensor went out it ruined the
computer. It turns out the computer is still covered under warranty,
but he will still have to pay for the sensor.
I have never heard that a sensor going out will destroy the computer
as well. Is this for real, or are they just trying to get him to pay
for the sensor, because they misdiagnosed the problem in the first
place.
Thanks,
Gary Dyrkacz
REMOVETHISBEFORESENDINGdyrgcmn@comcast.net
Radio Control Aircraft/Paintball Physics/Paintball for 40+
http://home.comcast.net/~dyrgcmn/
place.
Thanks,
Gary Dyrkacz
Guest
Posts: n/a
Re: Honda Civic: oxygen sensor causes computer failure?
The 1991 civic hasd the ECU/CPU well protected from most abuse.
I had a chance to diagram(mostly) one in an attempt to repair it.
I would suspect the failures where coincidence, or the failing(ed)
ECU killed the O2 sensor with too much gas. I would insist
they note the ECU failiure because the cat convereter could be at risk.
They don't like excess fuel.
Terry
Terry
Guest
Posts: n/a
> place.
> Thanks,
> Gary Dyrkacz
Like TeGGer said. . . . Somebody 'let the smoke out' and said OOoops !
'Curly'
> place.
> Thanks,
> Gary Dyrkacz
'Curly'
Guest
Posts: n/a
In article <qbqj41du322qktqps7bkhotcgq2b0r2vij@4ax.com>,
> place.
> Thanks,
> Gary Dyrkacz
It sounds like they screwed up. Tell them to put the original sensor
back in or give you the new one free.
> place.
> Thanks,
> Gary Dyrkacz
Myxalplyx
42
04-29-2016 05:38 PM
