Glue for door vapor barrier
Old 05-04-2005 | 12:16 PM
Randolph
Guest
Posts: n/a
I need to replace the vapor barrier in the door of a friend's car. In my
Civic the vapor barrier is held in place by a chewing-gum like adhesive
that has held up well for over 10 years. Does anyone know where I can
find this type of adhesive?
Thanks
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
Brian Smith
Guest
Posts: n/a
Re: Glue for door vapor barrier
"Randolph" <trash@junkmail.com> wrote in message
news:42463F93.12D0A849@junkmail.com...
I don't know where you could find that off hand. I would think that a parts
store would have it. Have you thought about using double faced tape?
Brian
John Ings
Guest
Posts: n/a
By vapour barrier I assume you mean the rubber weather strip.
In my experience only one thing really works:
<http://products3.3m.com/catalog/us/en001/auto_marine_aero/automotive_aftermarket/node_GSN04SFBB0gs/root_GST1T4S9TCgv/vroot_GSLPLPKL4Xge/bgel_GSZSZ5F858bl/gvel_Q5D2V4SCM0gl/theme_us_aad_3_0/command_AbcPageHandler/output_html>
Sorry about that rediculously long URL.
It points to 3M Super Weatherstrip Adhesive 08001
You should be able to find it at an automotive supply store like UAP
It's a yellow color and incredibly sticky. We used to refer to it as
"gorilla snot"
Michael Pardee
Guest
Posts: n/a
"John Ings" <nodamned@spam.org> wrote in message
news:62hd41lf5k2h3piq39uck42iprtdb61nku@4ax.com...
> "gorilla snot"
I think the barrier he's talking about is the plastic sheet between the
metal door and the interior panel. The stuff that holds it reminds me of
plumber's putty but is much stickier. I'd still expect it to be a 3M product
and it might be the same thing you describe. It definitely isn't rubber
cement, which would stink and harden.
Mike
Mike
Kenneth J. Harris
Guest
Posts: n/a
I don't know that you necessarily need to use the OEM stuff for this
sort of job. When replacing these barriers on various cars in the past
I have used GE SiliconeII clear cauking and a butyl cauking made for
sealing rain gutters. These were materials that I had tubes of availble
for cauking around my house and sppear to have adhered strongly and
sealed well. They certainly are made to withstand all types of weather
and moisture exposure.
Ken
> Thanks
motsco_ _
Guest
Posts: n/a
> Thanks
The closest thing to that gooey stuff is black 'acoustic sealant' which
is terribly messy. They use it to seal vapor barrier in houses, but it's
awful stuff. :-( Comes off your hands with WD-40. If you knew you were
NEVER going to open the door panel again, it might be OK. I just use a
bit of contact cement on top of the old sealant that's in there, to
reseal it. Since you're changing the whole gasket, you'll want something
closer to the real stuff. Hopefully a person who works at a good stereo
intallation place can tell you what to use.
'Curly'
John Ings
Guest
Posts: n/a
On Sun, 27 Mar 2005 08:05:58 -0700, "Michael Pardee"
Ah! That's just called a 'plastic cover' in the shop manual, but I can
see it's resemblence to vapour barrier. I think the 3M stuff would
hold it though. The shop manual just says 'apply adhesive' without
specifying what kind.
Kevin McMurtrie
Guest
Posts: n/a
In article <42463F93.12D0A849@junkmail.com>,
> Thanks
It's the same goo that seals the windows and tail lights, if that helps
you in your search.
Brian Smith
Guest
Posts: n/a
"Kevin McMurtrie" <mcmurtri@dslextreme.com> wrote in message
news:mcmurtri-F57C3C.10103427032005@corp-radius.supernews.com...
> you in your search.
I haven't seen any goo around tailights in years. The seals are rubber.
Brian
Randolph
Guest
Posts: n/a
Yes, the plastic sheet is what I am talking about. On the car in
question the sheet was held in place with an adhesive similar to what
you find on packing tape. After 17 years, it is now a slimy goo that
does not hold the sheet in place. I was hoping to find the the stuff
Honda uses, it seems to hold up very well over the years.
WaterWatcher
Guest
Posts: n/a
> Thanks
I've used plastic packaging tape for that with good results.
WW
Scotty
09-24-2005 10:37 AM
gwtx2
09-14-2005 12:30 PM
linuxgeek1
07-08-2005 12:34 AM
Handle-less
07-01-2005 09:56 AM
merlotbrougham@hotmail.com
05-04-2005 05:44 PM
