1999 Accord EX V6 moonroof not closing completely
Guest
Posts: n/a
Hi all
I slid the moonroof of my '99 Accord EX V6 open this afternoon. When I
wanted to close it later in the evening, it slid over 90% of the way back
but not all the way.
So there's a small open gap at the front of the moonroof and I can't figure
out what happened.
Any suggestions ?
Thanks.
out what happened.
Any suggestions ?
Thanks.
Guest
Posts: n/a
Re: 1999 Accord EX V6 moonroof not closing completely
On Tue, 08 Mar 2005 00:00:10 -0600, Bill <bill@hotmail.com> wrote:
>Hi all
>out what happened.
>Any suggestions ?
Get yourself a small spray can of white grease at an automotive supply
store. Open the moonroof all the way. Clean out any dead leaves,
defunct grasshoppers and other crud you can see, then spray the
channels that the moonroof mechanism slides in. Cycle the moonroof
open and closed a few times.
Other lubricants like WD40 will work temporarily, but don't last.
>Hi all
>out what happened.
>Any suggestions ?
Guest
Posts: n/a
I have that problem from time to time with my '99 EX V6. Open the roof all
the way. Near the front end, on the outside of the track, there is a metal
pieces that has a screw holding it down. You will see that it is loose.
Not sure what this does really, but I just tighten it back down and all is
happy again.
While open, do lube up the tracks and don't forget about the "pop-up" tracks
as well. You have to get them from the inside. Heck, while at it, do the
door hinges too!
-keith
tallahassee, fl
"Bill" <bill@hotmail.com> wrote in message
news:XPqdnXdKk-z3orDfRVn-pw@comcast.com...
> Hi all
figure
> out what happened.
> Any suggestions ?
> Thanks.
happy again.
door hinges too!
-keith
tallahassee, fl
> Hi all
figure
> out what happened.
> Any suggestions ?
> Thanks.
Guest
Posts: n/a
On Tue, 8 Mar 2005 23:38:32 -0500, "Keith J" <_keith_757@comcast.net>
>happy again.
>door hinges too!
>-keith
>tallahassee, fl
I have a similar problem on my '94 GS-R. In my case there is a
plastic slider in the track that has a broken spring. manually
sliding it in one direction or the other (can't remember which) solves
the problem for months at a time.
>> Hi all
>figure
>> out what happened.
>> Any suggestions ?
>> Thanks.
>happy again.
>door hinges too!
>-keith
>tallahassee, fl
>> Hi all
>figure
>> out what happened.
>> Any suggestions ?
>> Thanks.
Mike 01Hawk
09-11-2007 01:32 PM
Enrique Gonzales
05-04-2005 04:44 PM
