Stuck caliper?
Guest
Posts: n/a
Stuck caliper?
Hi,
When I drive my 1990 Civic I occasionally hear slight squealing sound,
such as if a front brake pad were touching a rotor. The sound goes away
if I slightly pull the steering wheel to the left, but comes back if I
let it go straight or slightly pull it to the right. I think that one of
the calipers gets occasionally stuck on its pin guides, but am not sure
which one it is and how to find out which one it is. Would anyone have
some suggestions on pinpointing the offending part and how to fix it
besides simply taking the front breaks apart, cleaning the guides, and
applying high temp grease to the guides?
Thank you,
Alex.
Thank you,
Alex.
Guest
Posts: n/a
Re: Stuck caliper?
It would be advisable to check your wheel bearings.
> I think that one of
Don't you do maintenance on your brakes, or have it done?
>Would anyone have
No, that's how you do it. It should be done regularly anyway, even if
it's not making noise. At least once a year.
http://www.tegger.com/hondafaq/faq.html#brakes
> I think that one of
>Would anyone have
Guest
Posts: n/a
Re: Stuck caliper?
after a drive go out and spit on the lugnuts, if it sizzles you
definately have a brake dragging. is the car pulling in that
direction? i had a problem like that with my '93. it turned out
to be a collapsed flex line to the caliper.
>Hi,
>Thank you,
>Alex.
>Hi,
>Thank you,
>Alex.
Guest
Posts: n/a
Re: Stuck caliper?
Drive the car a fairly long while, stop somewhere and feel (carefully, don't
want to burn your hand) each wheel hub. you will be looking to see if the
front hubs are both about the same temperature and the rear hubs are about
the same temperature. One side that is noticeably hotter than it's opposite
twin has some kind of problem, probably a mechanical problem, such as the
caliper not floating back after brake release, as you suggested, or a fluid
problem, with pressure being held in the system, as someone else suggested.
Next I'd jack up each end and try to spin the wheels by hand. Is one harder
to turn than the one on the other side of the car? That too would indicate a
problem.
If you find that one corner exhibited drag by any of these methods, or all
did, as in the case of a master cylinder problem, that would at least give
you an idea where to start.
Good luck
"Alex" <spork@narod.ru> wrote in message news:42094d9b@news.ColoState.EDU...
> Hi,
> Thank you,
> Alex.
problem.
Good luck
> Hi,
> Thank you,
> Alex.
Guest
Posts: n/a
Re: Stuck caliper?
Your problem is probably nothing more than a piece of rust dragging on the
disk somewhere. If the caliper was hanging the pads would be wearing, the
disks warping and getting extremely hot. Stop being lazy and pull the wheel
and check it out......
"gsl" <novascrollerNOSPAM@inherentsys.ca> wrote in message
news:422afc68.8618128@nntp.inherentsys.net...
>>Hi,
>>Thank you,
>>Alex.
>>Hi,
>>Thank you,
>>Alex.
Tralfamadorian
12-30-2013 02:40 PM
esamson7
06-02-2010 01:17 AM
