Show me your camera gear!!!!
#581
Yeah I saw that after I posted that up. I will definitely check that out thanks for the suggestion. Also as far as flashes I am going in completely blind because I have no experience with them and have never even looked into one but thanks for the info I will check out the sb's 600/800/900. Those all work off camera????? That would definitely be a big bonus.
#582
I will have to look into that more. I might end up getting the 800/900 later and just worry about the lens and camera right now. The wide angle will probably be down the road as well.
btw very nice website.
#586
Not necessarly. The fit would actually work out very well to transport photo equipment so if you were a professional photographer the fit would do you some good. But I am not pro and I don't have 3k+ to spend on just a camera body.
#587
i just realized that the d60 has a much slower flash sync speed than the d40... Do you guys think the slower speed would make a big difference? The only motion i would probably be shooting are cars and mountain bikes. I like some of the features of the d60, but now im not so sure if it will be a lot harder to get sharp shots.
#588
Also, keep in mind that when using flash, the shutter speed only has bearing on controlling the amount of ambient light/fill in the exposure (anything not lit by the flash). Anything lit by flash will be frozen b/c of the flash's short duration, so as long as your main subject is completely lit by the flash, it'll be stopped just fine regardless of the shutter speed.
#590
It's shouldn't make too big a difference. Most cams are @ 1/200-1/250 for flash sync; the D3 is at 1/250 for example. What's more important is that on the D40 you only have CLS capability if you're using an external flash as the commander (SB-800 or 900), whereas on the D60 the pop-up can control and remote trigger off-camera flashes. That's much more useful than a higher sync speed.
that's good to know too. i'm still new too all this stuff and i've been reading as much as i can. Hoping to have my camera next month.
#591
Generally true, but some situations warrant it. Motorsports photogs will often use remote flash for events where the ambient drops down too far to allow a reasonable shutter speed, i.e. the last few hours of ALMS Sebring for example. You'll often see from the overhead shots all the flashes going off at the corners when cars go through b/c it's simply too dark or too contrasty using just the corner lighting alone. Motocross shooters also use it also for lighting jumping riders so their underside isn't lost in the shadows. Rear-curtain sync flash can also give some neat effects in low light w/ moving vehicles.
#592
FYI: The D60 on-board flash does NOT trigger the Nikon CLS system.
The D40's 1/500 flash sync speed is a very nice feature and would come in handy greatly outdoors if you're using flash for fill light, otherwise you won't notice it that much.
#593
My apologies then -- I was going off of the spec sheets on Nikon's HP for the D40 and 60 and while they listed specifically the D40 only does CLS w/ a commander, the D60 just has "yes" listed for CLS, so I assumed they meant it carried the full CLS feature set. My bad.
#596
That lens should be quite nice. I haven't seen any shots from it yet, but for crop cams it's what a lot of people have been asking for it seems. Definitely post some once it comes in.
#598
No harm at all, I didn't take it wrong in any way. Correct info is the only good info, and I wouldn't want to mislead him either.
