HKS Turbo Kit+ FREE Install!
Hey everyone! As some of you may know I have been a member of FF for sometime and just became a merchant for my company. If you guys have any questions feel free to contact me via AIM or PM me! Thanks
HKS USA Bolt-on Turbo Kit - Honda Fit
$3,495.00 + FREE Install
Remember Folks!
1. SP offers a Lifetime warranty on Labor.
2. SP is an HKS Pro-Dealer, which means that we are authorized to Install any HKS parts.. INCLUDING F-CON
Kit comes with: T25 Turbo, S-Type Intercooler, F-Con IS (Pre-Programmed), Cast Manifold, Downpipe, SMF Reloaded Intake, Polished Aluminum Intercooler Piping w. SSQV Flange.1. SP offers a Lifetime warranty on Labor.
The HKS Honda Fit Bolt-on Turbo Kit (CARB E.O. # D-186-27) was developed with reliability and performance in mind. The simple-to-install Turbo Kit includes a front mount intercooler, which improves charge air density, while enhancing the engine performance. The pre-programmed HKS F-Con IS engine management system included in the kit maintains the proper fuel and timing strategies.
The T25 Turbo allows for a faster spool up at a lower RPM range resulting in better response and low-end acceleration. HKS SMF Reloaded intake system, included in the kit, allows for improved filtration and increased airflow.
With the turbo boost level pre-set to 5.7 psi and tuned with the Pre-programmed F-Con IS on 91+ octane fuel, HKS' bolt-on turbo kit, combined with the optional HKS Hi-Power exhaust and upgraded HKS spark plugs produced a performance gain of approximately 30 % gain in peak horsepower without significantly impacting the excellent MPG the Fit is known for.
The 2007 Honda Fit Bolt-on Turbo Kit has earned CARB E.O. # D-186-27.
Also, it is CARB legal.
PM Replied!
yeahi just looked it over too...hmmm this is a definite possibility.
and they do custom fabrication of course. so can yall build a heat shielf for the manifold. apparently the hks kit has a heat problem around that area.
they have a 2JZ rx7 thats amazing!!! SP Engineering is a very reputable shop and the people working there are awesome! I have purchased some parts from them! Buy with confidence
I just talked to HKS and they said it was never tested on the AT because you would have to retune it to auto because its already pre-programmed.
I guess it was just a rumor when i heard HKS will be making two sepreate kits for both transmissions.
Tyler
ya i suppose it was just a rumor. oh welll
