2015 Honda Fit Service questions
Old 05-21-2018 | 09:51 AM
Matts1stHonda's Avatar
Hi All!
My 2015 Honda Fit has 67k miles on it and going strong. Love this car to death! A few questions regarding servicing my Fit. I haven't gotten any tune-ups yet but I get an oil change every 7k miles. Can you guys let me know when I should replace:
1) Spark Plugs
2) Timing Belt
3) Brake Pads/Rotors
4) Brake Drums
I want to do all these myself as I would like to learn it. Also, is there anything I am missing? Thanks in advance for all the feedback!
Old 05-21-2018 | 01:55 PM
evilchargerfan's Avatar
DOWNLOAD SERVICE MANUAL HERE ---> https://techinfo.honda.com/rjanisis/...999O00132A.pdf
I believe, this topic may have already been covered:
https://www.fitfreak.net/forums/3rd-...-schedule.html
Old 05-21-2018 | 01:58 PM
BUT .... just in case .... you dont want to read through all of that .... I'll play along:
https://www.southpointhonda.com/hond...e-schedule.htm
HONDA RECOMMENDED MAINTENANCE SCHEDULE
7,500 - 22,500 - 37,500 - 52,500 - 67,500 - 82,500 mile maintenance
  • Oil and filter change
  • Inspect brakes for wear
  • Lubricate throttle linkage
  • Check and correct fluid levels
  • Inspect tires and set tire pressure
  • Rotate tires
15,000 - 45,000 - 75,000 - 105,000 mile maintenance
  • Lubricate chassis and hinges as required
  • Replace oil drain plug, gasket
  • Rotate and balance wheels and tires
  • Inspect undercarriage
  • Inspect crankcase filter
  • Inspect shocks and struts
  • Torque throttle body mount bolts
  • Inspect throttle leakage
  • Check and adjust clutch pedal freeplay as applicable
  • Inspect distributor cap-rotor-wires
  • Inspect A/C and heater operation
  • Service transmission
  • Check park brake adjustment
  • Inspect all lights and wipers
  • Replace air filter
  • Inspect for trans. leaks
  • Level control
  • Steering systems
  • Fuel and break systems
  • Replace spark plugs (if necessary)
  • Inspect and adjust drive belts
  • Inspect air filter elements
  • Rotate tires
  • Inspect brake system
  • Adjust parking brake
  • Check all exterior and interior lamps, windshield washer systems
  • Lubricate throttle shafts
  • Inspect drive shaft boots
  • Inspect differential oil
  • Inspect exhaust pipes and mountings
  • Inspect steering gear box
  • Inspect steering wheel, linkage, and boots
  • Inspect road test vehicle
  • Inspect ball joints and dust covers
  • Inspect brake lines and hoses
  • Inspect brake linings/drums and brake pads/discs
  • Inspect automatic transmission fluid
  • Replace windshield wiper insert(s)
  • Re-torque drive shaft bolt
  • Re-torque propeller shaft bolt
  • Lubricate all hinges and latches, door locks and door weather-strips
  • Lubricate propeller shaft
  • Replace air conditioning filter
30,000 - 60,000 - 90,000 - 120,000 mile maintenance
  • Replace engine air filter
  • Inspect for leaks
  • Level control
  • Replace engine coolant
  • Inspect drive belts and adjustment
  • Inspect brakes (visual)
  • Service PCV valve
  • Replace fuel filter
  • Service battery and clean cables
  • Inspect exhaust system
  • Inspect brake line and hoses
  • Differential oil
  • Inspect fuel tank cap gasket
  • Inspect steering wheel, linkage and boots
  • Inspect transmission fluid or oil
  • Inspect fuel lines & connections; fuel tank band & fuel tank vapor vent system hoses
  • Inspect transfer case oil
  • Lubricate wheel bearings
  • Lubricate wheel bearings and drive shaft bearings
  • Road test and quality control
  • Automatic transmission oil and filter change
  • Air filter replacement
  • Spark plug replacement
  • Propeller shaft flex coupling inspection
  • Inspect parking brake for free play
  • Visually inspect battery and clean terminals
  • Inspect tire pressure and condition
  • Inspect coolant hoses and clamps
  • Inspect fuel lines and connections
  • Inspect engine valve clearance
Soon2015FitWillBeMine
07-23-2024 08:57 AM
jlbryan027
05-22-2016 01:14 AM
Peterjens
06-20-2015 10:29 PM
HermTDI
03-16-2015 10:32 PM
Buck Fitty
06-05-2014 12:37 PM
