Per salesman new Fit will get 350,000 to 400,000 miles
Old 06-22-2023 | 01:14 AM
TnTkr's Avatar
Originally Posted by john21031
If you replace the engines, you can drive the thing to 20 million miles.
To make it to 500K, you will probably replace few alternators, water pumps, axles, numerous tires, coils, plugs, possibly a few major gaskets, clutch (depending on how u drive).
You are right if the annual mileage is high, otherwise rust on the body is most likely reason to end the life of a car.
  #42
Old 06-25-2023 | 12:27 PM
woof's Avatar
Pretty much all the cars I have ever owned were scrapped because of rust. My Camry was 34 years old when I scrapped it. Near the end I was jacking up a corner of the car to change a tire and the jack just went right through the metal. That was at a jacking point too. Still kept it for a little while longer until an electronic ignition module went. Replacement was available on the aftermarket but it was time to let go. Bought the Fit a short while later.
I used to believe that manufacturers had to make replacement parts available for 10 years but that's not true. They're really only required to have parts available to cover the warranty period of the car. That's typically 5 years at the most.
GolNat
06-14-2019 12:18 AM
KeithDLewis
Mid-Atlantic Community
08-08-2017 07:34 PM
coldstorage5
06-04-2011 10:25 AM
Lynn
06-15-2009 06:03 PM
jijifit5000
05-20-2009 01:17 PM
Quick Reply: Per salesman new Fit will get 350,000 to 400,000 miles
