front end shake
front end shake
i have gd3 and recently noticed that when i brake from 65mph or higher my front end shakes like i can feel it through my steering wheel,and a lil bit on pedals too..only happens on that certain speed nothing when im on streets cruising ike 50mph below..and its worst when brake going downhill..is it my rotors?..anyone?..
My vote goes to rotors also. It's the only one related to braking among the three areas you mentioned. Had that feeling with another vehicle of mine - warped rotors.
Engine mounts and axle issues wouldn't come up as braking symptoms. Just my take.
If it were axle shafts, you'd have vibration whenever you're moving at speed, not just when you're braking. If it were engine mounts, it would be more related to throttle action than to braking. (I think engine mounts more typically caus a single clunking sound as you transition from accelerating to coasting or back and the engine rocks one way or the other, rather than a more extended vibration; however, there there may be other symptoms I'm quite ignorant of.)
Beerman182
06-27-2005 08:22 AM
