Loose tailgate pull pocket
I recently removed the back panel on my tailgate and I could not put the pull pocket back. Every time I try to stick it in it just keeps falling off. There doesn't appear to be anything broken. What am I doing wrong?
Still not in? Can't see the clips in your pic but think they are not engaging.
Take the main piece off and insert the handle. Maybe that way you can help the clips engage from the rear. Then put the main panel back on.
This is the pull pocket for the tailgate.
You got that right, I have a GD. It just came off when I removed the back panel so I am not sure what was holding it in before I removed the panel ...
You are welcome.
It looks like in the first pic that there are 4 small tabs broken off where it shows white. It appears that those sections would be depressed when pushing it in and then snap up to hold it in place. The other side would have been inserted first then this side.
I guess a trip to a dealer to see a new one would help.
You are welcome.
