idler pulley
idler pulley
Does anyone have pictures of the pulley assembly? When I took it off 2 bosses and a big curved washer fell out. I've put it back together twice and it's still not right. I sound like dork but I don't want to crawl under the car for a to many more times
Thanks
Ed
Thanks
Ed
Take the picture and upload it to a free Photobucket acct. Once uploaded to Photobucket, copy/paste the IMG code into the body of your post. That easy.
Yup, that's the one I'm looking for. Mine is a 2008 GE sport. I put it together without that big ass washer and so far so good. Thanks for all the info.
On second thought, maybe I should put #14 on. What does that washer do?
Another thing I found out the hard way, you have to loosen that bottom bolt on the alt. 6" ext and a shallow socket worked for me.
I tried that but I just had the IMG with a red X instead of the pic. Let me try again
Under the picture in photobucket, you will see "direct link" and a few others. If you just click on the IMG code, it will automatically copy. Just paste it over here.
I know this is a old thread, but i had the same problem. I bought a Gates idler pulley and after installed, the pulley doesn't spin freely. After some research, i found out the Gates pulley and the OEM one is a little different, the dust shield (the big ass washer as running call it item #14 on the picture) doesn't fit onto the Gates pulley, so i added a little spacer between the shield(#14) and the bearing spacer(#12), and everything works perfect.
I hope this helps everyone else who's having the same problem.
Giovanny Alan Alvarado
09-25-2018 04:55 PM
devmail
35
02-18-2015 05:28 AM
LastDance
11-13-2010 09:14 AM
