Rear end alignment issues?!?!?
Old 11-10-2011 | 04:46 PM
Stacey444's Avatar
Took my Fit in for new tires and an alignment. I was told that my rear end is out of alignment. They said that there is nothing I can do about it and that every Honda Fit that they have had in their garage has had the same issue. This is the first I am hearing of it......anyone else been told this?
Old 11-10-2011 | 05:36 PM
Krimson_Cardnal's Avatar
They are correct.
Did you walk away with an alignment print-out?
Here are the specs. If within Honda limits no issue.
Rear Camber: -1 ° 00 ’+/-1 °
Rear toe-in: 2.5+/-2.5 mm (0.10+/-0.10 in)
If the measurement for the rear camber is outside
the specification, check for bent or damaged
suspension components.
Old 11-10-2011 | 05:56 PM
Marrk's Avatar
Huh?
Old 11-10-2011 | 06:11 PM
GAFIT's Avatar
Ours is within factory specs, but wears the inside of the rear tires pretty severely. I have purchased the part necessary to fix it and have spoken with the mechanic that will do the work, but haven't had them installed yet.
Specialty Products Company
Old 11-15-2011 | 11:29 PM
Roadent's Avatar
I've owned two '09's and both had the rear toe out of spec.
Old 11-16-2011 | 05:58 AM
doctordoom's Avatar
Supervillain
How far out is the alignment? The rear toe can be out of Honda's specs to a certain degree, and it won't be a problem as long as you rotate your tires since there's not that much weight back there.
Old 11-16-2011 | 10:37 AM
Marrk's Avatar
I am really scratching my head over this thread.
I rotate my tires every 5k mi. Maybe that's why I haven't noticed any problems. Also, I assumed the OEM set-up on the car purposely had unusually high understeer, in order to reduce the tendency of some front-engine FWD cars to snap-oversteer. On that note, I haven't been able to get my car "loose" in the back at all.
Odie
11-25-2015 08:16 PM
Scotty2h
08-27-2015 06:05 PM
AutoFit
09-12-2012 08:55 PM
piperpiperpiper
05-10-2010 08:50 AM
coupdetat
02-20-2008 08:57 PM
Quick Reply: Rear end alignment issues?!?!?
