Progress RSB - you guys got SCAMMED!
Old 03-24-2021, 02:58 PM
mobby_6kl's Avatar
Okay, who's going to be the first one to go to a track and test before/after?
Not that I don't believe that it makes a difference, but it'd be great to quantify it somehow.
  #42
Old 03-24-2021, 03:11 PM
ikutoisahobo's Avatar
Cusco also makes a rear swaybar for the GE8 Fit's, here's how that looks:
Notice how it's the same general design as the Progress bar? 16mm vs 19mm for Progress.
Maybe more people will believe that the bar does something if it's coming from a very well known a d reputable company like Cusco....
  #43
Old 03-24-2021, 09:04 PM
Hootie's Avatar
Holy thread revival Batman! 2011 to 2021.. LOL
The Progress rear anti-roll bar been proven to be effective LONG ago as it is frequently seen on B Spec prepped GE and GK Fits for SCCA events as well as was one of the common bang for buck add ons for Fits running STF autocross events.
It effectively "pre-loads" or "pre-tensions" the semi-independent torsion beam to reduce flex during cornering... If memory serves me right it tends to similar to adding 50 lbs/inch of pre-load on the beam when used in conjunction with stock or Progress springs.
  #44
Old 09-19-2022, 12:32 PM
KrautBurner's Avatar
I found this #Cusco one while searching
found it interesting that it also has NO mid mounting points (poly bushings)
does someone make an Anti-Sway Bar with traditional 4 point mounting?
  #45
Old 09-19-2022, 01:32 PM
GAFIT's Avatar
I believe it's made the way it is intentionally. By not having middle mounting points, the two sides are able to have more impact on each other.
Regardless, I can tell you that the Progress bar on our GD with only two mounts works well.
  #46
Old 09-19-2022, 04:52 PM
I've only done anti-sway bars on RWD cars
I know they typically make a big difference
that's my biggest complaint about the handling of the FIT,
very significant body roll and front end plowing
  #47
Old 09-19-2022, 05:13 PM
GAFIT's Avatar
You'd be surprised at how much stiffening the rear helps. The bar, IMO, is more of a stiffening device than it is a sway bar.
Some of the fastest Fits on open road courses run a Progress rear bar and no front sway bar at all. They then tune to their driving style with spring rates. That is all to eliminate the understeer.
DOHCtor
16
11-14-2011 02:11 PM
Vtecguru
08-26-2011 11:35 AM
IN2TURBOS
02-22-2010 06:56 PM
allgocrx
08-28-2009 03:31 PM
Quick Reply: Progress RSB - you guys got SCAMMED!
