AEM FIC & Windows 7 issues.
Any AEM FIC-6 (30-1910) users having an issue with Windows 7?
Laptop died recently, bought another and it has a basic version of 7, now I not only don't have my .cal maps but I cannot get it to connect to the FIC.
I've tried the procedure from the AEM Forums (which are notoriously slow) and I am using version 3.04, with the FTDI CDM 20600 driver installed and the 4 hex files that come with 3.04.
Then I tried following the steps posted by an administrator here:
Windows 7 doesn't read FIC
Any thoughts from the more computer savvy among us? Any information I can share that would help diagnosis?
Edit:
Upgraded to 3.06, found a .fi6, and x3.81.hex and set the FIC to COM3 - USB
The error I get now is:
1. Install the FTDI USB drivers provided here
2. Plug provided USB cable into your F/IC and computer
3. Right click on "Computer"
4. Select "Device Manager"
5. Expand "Ports (COM & LPT)"
6. Double click "USB Serial Port (COM#)"
7. Select the "Port Settings" tab
8. Click "Advanced"
9. Change the "COM Port Number" to a number that is below COM16.
8. Click "Advanced"
Edit:
Failed to locate a functioning FIC. The problem might be the PC and FIC are not connected or- the PC has assigned a com-port above 16. Correct the problem and try again!
Oh and for anyone wondering the physical FIC install takes about 15 minutes with the boomslang harness some vacuum hose and a tee fitting.
1.) Empty glove compartment
2.) Pinch in the top of the "wings" at the back of the glove compartment
3.) Pull forward
4.) Loosen bolt and remove restraints on the harness
5.) Plug in BoomSlang Harness
6.) Party
Any screen shot requests from the curious while I wait? lol
3.) Pull forward
6.) Party
But, if your laptop has another drive bay, you could yank the hard drive from the old laptop, plug it into the new and access the data.
If your new laptop doesn't have a bay, you could go out and buy something like an external enclosure... or something more simple as a "multi-drive adapter"... for example: Apricorn - DriveWire Universal Hard Drive Adapter - Metallic Red - ADW-USB-KIT . then you can plug the old drive through the USB... accessing it would be slower.
This, of course is assuming the old drive isn't encrypted or the data stored in a windows password protected section (either case makes it mostly inaccessible).
Sounds like a lot of work for some .cal maps, eh?
hum... I'm no good at troubleshooting computer related issues over the phone/forum/etc. I have to fidget with it to figure it out.
I'd have no idea about the FIC (what is that?!?)... and to be honest, I haven't dealt with com ports since... um... windows 3.11 or maybe win95, I think. It's been a while. Did you make sure you picked a com that isn't already being used? That an "interrupt" number conflicts were a common hardware issue back then. Com ports ALSO use interrupts... and some interrupts are shared, but not all devices like sharing.
Just wanted to update... for whatever reason my FIC decided to cooperate tonight and was able to connect to my Windows 7 OS on the new laptop.
Moar pics:
Cannot say enough good things about the BoomSlang harness. The Fit being an extremely easy car to work on certainly helps too.
The last time I installed the FIC I removed the glove compartment and popped the panel underneath which takes all of 2 minutes.
Then run a vacuum line to a port on the intake manifold (post-throttle if you weren't sure) and through a grommet on the firewall.
From stock to turning the key with the FIC installed took just shy of 15 minutes done in the dark with a flashlight. I keep my FIC mounted in the glove box.. for a real sleeper look. I am going to be hiding the throttle controller as well and keeping the majority of the exhaust stock save for a big cut-out when I go turbo.
Moar pics:
slimchriz
09-18-2014 06:21 PM
dustinb
02-06-2012 05:04 PM
DOHCtor
05-14-2011 12:10 PM
Spooling
05-17-2009 09:08 PM
