Air Conditioner Smell
Old 05-18-2011 | 06:39 PM
DeeezNuuuts83's Avatar
Here is a solution:
DWD2 - Products
I'm probably going to have this done on my car. I've been spraying Lysol into the vents as a cheap temporary solution, but I think I'll just do this since I'd rather just get it done, especially since my car is about five years old now.
Old 04-15-2012 | 09:52 PM
Jred's Avatar
Brand new 2012 not three weeks old smelled like dead fish. I did the heat thru the vent trick
and run on fresh air mode instead of recirc, seems to have solved the problem.
Old 04-16-2012 | 02:16 PM
jjsifo's Avatar
Smell on Acceleration
a
Originally Posted by gcisko
Yes I usually (95% of the time) turn the AC off before shutting off the car, but only a few seconds before turning off the car.
Should I change the vent from recirc to outside air at the same time too? I've never done this before, but if the system is shut down with air trapped in the recirc mode, I do understand the issue.
What about the smell only happening on acceleration? It's there only for a few seconds then it's gone. Could this be some combustion byproduct or exhaust gas that's making it's way into the vent system?
Same here, ,my two cents worth: on acceleration there is almost no vacuum to hold any vent doors open or closed,have no idea how the FIT is setup as far as vent doors go, I'm talking old technology here,without vacuum reservoirs,or broken ones, good luck, JJ
Old 10-21-2012 | 03:34 PM
pattypetitw's Avatar
I just purchased a 2012 Honda Fit and have the same problem with the rubbing alcohol smell. I live in Florida so always use the AC. Guess I'll take it to the dealers and see what they will advise. The smell gives me a headache.
Old 10-21-2012 | 05:54 PM
wierd, i just leave the hvac in the setting it is when shutting off the car. no issue on my 09 or 12. no stench, no rubbing alcohol smell. i try to use the a/c as much as possible.
Old 10-21-2012 | 08:24 PM
My son-in-law said it could be some kind of chemical they spray on the hoses and the smell should go away after awhile. I still think I should have it checked so it's on record.
Old 02-14-2014 | 01:03 PM
Atmos's Avatar
This moldy funky smelly socks smell comes from the AC condensor, not the vents. Turning the heat up does not help. It is a design flaw with the tiny AC unit. You have to get one of those cans of cleaner with the long hose that goes all the way to the condensor.
Old 02-14-2014 | 02:08 PM
connor55's Avatar
Mine smelled mildewy when new, but it's gone away now. When I had the problem, running the AC seemed to make the smell go away. Don't smell a thing anymore.
Old 02-14-2014 | 05:06 PM
yah, i keep the a/c running at all times. no musty smell.
if it persists, you could have a blockage on the evap drain. would help to check it and clean it while you're doing your oil change.
Jeff Jeffro Tompkins Sr.
08-11-2016 10:58 AM
jjrbus
05-31-2014 10:05 AM
jlatus
10-07-2012 10:06 AM
Chris Nicola
05-21-2009 03:54 PM
7red7
08-26-2008 12:34 PM
Quick Reply: Air Conditioner Smell
