Sports Mode, Paddle Shift
My car will not engage in the sports mode, when it's in S mode, it just drives as if it's in the D mode. Anyone has this experience and how did you resolve it? I'm hoping for a simple fix cause Honda wants $210 to diagnos.
yah, you have to hit one of the paddles to enter manual-shift mode. otherwise it's in sport shift mode which is still automatic.
but if you rev high it will shift up on its own even in manual mode. so it's still in automode. very confusing transmission.
It should be noted that this is a kinda good thing. If you're making a sharp turn out of a parking lot or something, you can lose the paddles for a second. This way, you can accelerate as needed then shift manually when the wheel returns to a relatively normal position.
yah, or just floor the thing and it will shift up automatically when it hits redline.
![Rolling on the Floor](https://www.fitfreak.net/forums/images/smilies/rotfl.gif)
lol... i've used the paddle shifter before and no this is not a user error. I know how they work. The problem that i have is that the S mode and paddle shifter no longer engage. I'm always in D mode even if i'm in S gear. Cruise control will not engage either. They've told me it may be some kind of switch problem or something else. There's no signal going to the computer for those two items at all.
hi, i dono if u still go on fit freak at all. but apparently.. this is a pretty rare problem, since i cant find anything on google. My S mode also will not engage. did you ever find out what the problem was? My cruise control still works..but not the S. it's a shame, cuz i use it quite often to drive at lower gears.
