shifting in automatic transmission base fit
just bought the fit the other day, what a great car! i wanted to know if anybody uses the gear shifter in an auto like a manual . i don't want to break anything. but it seems like the car wants to be driven that way .does anybody else drive like this? i have no paddles. thanks in advance.
Are you talking about moving the automatic shifter up and down the D1-3?(or w/e it may be) Sorry, but it's not exactly what you think you're doing or rather think what it is.
What you are doing is shifting through different gear modes, not actual gears
yes i am talking about the automatic shifter 1 thru d .i uderstand that you can change the gears in s mode but woundnt that be the same thing as shifting up and down on a a automatic base?and i also was worried about wearing out the auto shifter .thanks for your opinion secondspassed i didnt think of it like that
The feature was not designed to allow the user to manually shift their automatic, obviously, or else they would have added 4th and 5th.
honda added rpm fuel cutoff, but that doesn't mean it's ok to redline the engine everytime.
am i serious about what. ijust thought the s mode lets you drive manual without a clutch. had to go outside and read the manual.it said that it would hold the gear longer in s mode than d mode.sorry if this sounded stupid i never owned a stick!
Doh! be careful there... The feature was designed to aid in specific conditions like dead stop starts on ice, or going downhill.
I agree with secondspassed i think if Honda didn't want you shifting they would have made you stop the car to change gears. as i see it the base can be run just like the sport where as the sport has hands on control rather than reaching for the shifter.one other question while i have you guys.does engine breaking waste gas?
online download of the 2008 manual:
"By upshifting and downshifting
Also, it doesn't appear that position 1 or 2 will allow the trans to up or down shift... but that makes sense.
through 1, 2, D , and D, you can
operate the transmission much like a
manual transmission without a
clutch pedal."operate the transmission much like a
In other words, Honda designed our ATs to engine brake.
i was just talking to a friend of mine who works for the honda service department for 20 years .he told me by all means drive it like that! made me feel a lot better.then he added you got 60000 on the tranny warranty and laughed
