Refresh Mode
Refresh Mode
Can anyone tell me how to put the seats in the Refresh Mode? I have pushed the passenger seat forward as far as it would go, removed the head rest, but it would not recline to be flush against the rear seat Thanks.
June 2007 3rd Place Fit of the Month Winner
It was tough for me at firest too. However, I found out that you have to recilne the rear seats to. They go back just a few inches, but that will allow the front seats to properly go down. You might have to give them a little push. They don't go down with ease.
you've to recline the back seat (that's the trick).
Look for the levers on back seats and pull those while pushing back the seat. It'll permits to recline the seat for about 3 inches and lock in place so the front seat can flush. Try it! It's easy. But be sure the back seat is well lock in case of braking.
Yay, it worked! Thanks everybody!
The problem wasn't my rear seat not being reclined...It was that I had the front seat all the way forward in the locked position! Once I moved it truely all the way forward it worked!
This takes too much effort to be relaxing...If anyone is planning to use it for some "intimate" purposes, I believe that setting this thing will kill the mood
Is it illegal/risky to drive while someone is buckled up in refresh mode while the car is moving ?
