View Poll Results: What Type of Induction?
Intake
18
31.03%
Stock Airbox
34
58.62%
Modified Stock Airbox
10.34%
Voters: 58. You may not vote on this poll
Feeding the Fit
when spoon tested the output of a cold air intake, they found that the stock air box with an insert made more power so id say, take off the resonator on the side and throw in an aftermarket insert.
i had a Fujita short ram intake, took it off and tried the modified OEM intake box + high flow filter. throttle response was MUCH better with the modified box and power (using that term loosely) was where i needed it for daily driving -- between 2.5k and 4k rpm.
all i did was remove the resonator and cut out all the baffles. the best part is how stock it looks
back when i installed my CAI, i didnt think much of throttle response... if i look back today i'd probably prefer it... But after hearing the sexy intake growl, i dont know if i could ever go back
By the way I use the stock airbox too. Seeing as how you guys are getting good results with K&N drop-ins...maybe I'll do that.
A related question:
Why do you get more consistent performance with the stock plastic airbox vs. SRIs? Does the plastic and the design/length have to do something with it?
i'm sure the stock one is "engineered" for best all around performance. The stock intake will be what most people use so im sure they test it for the best results. They (at least i think so) probably get lots of time to fully test what's best and dont have to worry about marketing it or quickly releasing it as an aftermarket company prolly would. I dont know... haha
Same here!
A related question:
A related question:
