Jazz engine noise
Jazz engine noise
I have a jazz automatic. At 6500 miles I noticed a noise at 1100 revs. This was only when under loar and in first gear. I went to a dealer. They tetsed it and eventually agreed ther was anoise. they said it was engine resinence. ther was nothing that could be done. I do not agree. Honda built a fine car and they build brilliant engines. So why cant this be fixed. Does anyone else have the same problem??
Hi Tanker,
If you have the CVT you might want to check out this thread.
https://www.fitfreak.net/forums/fit-diy-repair-maintenance/3155-cvt-vibration-help.html
talks about several other Fit owners who have had a CVT vibration. Seems a transmission fluid change fixed it right up.
Also you can give it a read and see if your symptoms are similar.
Hi mate,
Thanks for the information. I have again contacted my dealer who have just had a supply of a new type of oil for the CVT. They are going to change the oil and see what the effect is. The technician who came out with me did hear the noise. If the new oil works the will also replace the oil in 2 other Jazz's who's owners have had the same problem. It seems to me that this is a known problem that dealers only sort out if people are persistant.
Thanks
Thanks
Originally Posted by tanker
Hi mate,
Thanks
Thanks
oil
Hi mate,
No it was not this type of oil. they tell me my Jazz has the Honda oil. However honda have a new oil out which is designed to stop gearbox noiseaand clutch slip. I will know on friday when they do the oil change. Will keep all informed of the result..
Take care.
Pete
Take care.
Pete
