Auto transmission shifting 1st to 3rd?
Old 09-09-2008 | 07:57 AM
mmm def's Avatar
Seems sometimes under light throttle that the tranny will go from 1st to 3rd and then quickly back to 2nd. It's annoying. 30k on the car, does it randomly.
Old 09-09-2008 | 08:59 AM
Firebat666's Avatar
your covered under warranty... bring it in and have them look at it
Old 09-09-2008 | 11:05 AM
n6nev's Avatar
If you let up on the throttle in first gear and the vehicle speed is above a certain level, the ECU will put the trans in third, then you apply just a little throttle and the ECU will then allow the trans to go into 2nd gear. For a test, apply a steady throttle and you will achive a 1 2 3 4 5 shift pattern....
Old 09-09-2008 | 11:26 AM
David R's Avatar
Sounds more like user error like n6nev was hinting. Perhaps you are releasing so much throttle that the car understands you to want it in a higher gear so it just bypasses second.
Old 09-09-2008 | 11:47 AM
mmm def's Avatar
Not at all, foot is down on the gas with constant pressure..why would I let off between shifts? Just wondering if anyone experiences this. Not really a big deal.
Yeah you take it to the dealer and get the typical no problem found.
I'll live with it, as it doesn't do it all the time.
Old 10-09-2008 | 08:43 AM
badself's Avatar
My '03 Honda Pilot started off with mild transmission shift glitches, and within three months the transmission was shot (with the associated flashing "D"). Some transmission problems behave like computer viruses, seemingly innocuous at first, and then......
Taking it to the dealer has documentation value. Maybe they'll say "No Trouble Found", but if you have a trans failure a year later and ask Honda for goodwill consideration, you're more apt to get it with a documented history.
On the '03 Pilot, Honda took nearly a month to come back and say they'd cover the rebuilt trans ($2,300), and I'd pay $630 labor. I took them up on the offer and then tranded toward an '09 Fit.
Old 10-15-2024 | 11:27 PM
Greyt Threads's Avatar
I have a 2013 base model that just started shifting very hard. It only has 1st & 3rd no 2nd 4th or 5th. The "D" light is flashing, I added most of a qt of Dextron VI but no change. And the D is still flashing.
Old 10-16-2024 | 09:02 AM
Drew21's Avatar
Did you add a quart of ATF because it was a quart low? If so, how long were you running it without the proper amount of ATF? Obviously, running a transmission without the proper amount of ATF will lead to problems and damage, as suggested by your flashing "D."
It's probably time to visit a transmission shop.
noneterry
02-20-2015 10:54 AM
purplekush
06-06-2013 02:45 PM
BraytonAK
05-25-2013 11:32 AM
Steven Hung
01-24-2009 03:21 AM
danger69
08-31-2007 10:00 AM
Quick Reply: Auto transmission shifting 1st to 3rd?
