seat lowering
Old 08-22-2008 | 03:51 PM
MemphisFit's Avatar
seat lowering
is there any way to drop my seat down about an inch to inch 1/2???
i feel like im sitting on top of the steering wheel
Old 08-22-2008 | 07:22 PM
MemphisFit's Avatar
NOBODY????????????????
Old 08-22-2008 | 07:29 PM
Tofuman's Avatar
you'll probably have to get an aftermarket seat and seat rails. i don't believe any seat rails fit the OEM seats.
Old 08-22-2008 | 07:48 PM
ClaytonS15's Avatar
I wish I knew, because I would love to raise my seat about 1/2". My right leg cramps up on long drives...
Old 08-22-2008 | 07:58 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
yeah aftermarket seats/rails should do the trick
Old 08-22-2008 | 08:07 PM
Tofuman's Avatar
j/k.
Old 08-22-2008 | 08:13 PM
ClaytonS15's Avatar
Originally Posted by Tofuman
j/k.
That's one solution! Lol!
Old 08-22-2008 | 08:25 PM
Tofuman's Avatar
in all seriousness, you might look into finding a seat cousion that extends past the seat bottom slightly to support your leg and may raise your seating position a little. at least until a better solution is discovered. it will be better for your legs.
Old 08-22-2008 | 10:33 PM
mahout's Avatar
Only a machine shop fabrication will shorten or lengthen the legs. Probably with inserts in cutoff legs. Not real easy to do.
As mentioned you can search after market seats for easier solution.
Old 08-23-2008 | 01:05 AM
Tofuman's Avatar
Originally Posted by mahout
Only a machine shop fabrication will shorten the legs. Probably with inserts in cutoff legs. Not real easy to do.
good idea for an alternative. but i'd have a hard time trusting a machine/welding shop to customize something as important as seat brackets/rails. in the event of an accident, i want some seat rails i can trust.
Old 08-23-2008 | 03:30 AM
well, the only upside would be if you got in a wreck and they broke, you could sue!!!
can someone say FI?!?!
haha but really that would suck
Old 08-23-2008 | 03:34 AM
hotpot's Avatar
I have a problem with the seats too, i went on a 50 miles on the highway and my butt/back/lower leg is still hurting. maybe moving the seat all the way back?
Old 08-23-2008 | 03:44 AM
ProMed's Avatar
Several guys, who do not have the height adjustable seats, on the 4Runner boards I frequent have put washers under the bolts that hold the rails to the floor. Most guys were just putting them under the rear bolts to tilt the seat forward, but some were putting them under both the front & rear. Not sure though how the Fit rails are attached?
crozewski
10-21-2015 04:41 AM
JaStonE
01-03-2011 03:28 PM
DGArch
10-19-2010 10:09 AM
rac1201
12-22-2007 05:02 PM
pastafarian
11-24-2007 11:44 AM
