Towing behind MH, some ??
Wiring routing
I checked my 13 Fit Toad (Sport Auto) for the easy wire routing and I see that I actually removed the left foot pad (this may be unique to the Sport). I then found a rubber area underneath the pad that made for a very easy routing into the driver's floor area.
Looking at the Blue Ox base plate, the Hopkins lighting kit (plug ins, no drilling into light box) one-time installation, brake relay and the NSA ReadyBrake supplemental braking system and emergency breakaway system. adding a RVI towed battery charger and a Drive/tow fuse switch instead of pulling the mini-fuse each time. About $1,500 in all said and done.
Steve
Brand new to the forum, but wanted to add my two cents and what I have found, plus get some feed back from you all! We have a 2010 Honda Fit Sport manual trans. Bought a good used HM last summer with a tow bar and looking at setting up the fit to be towed behind for this summer. Internet searches led me to e-trailer.com (several good ones found) and the products & expertise they offered. (videos and Q&A)
Joined the forum to see how you all get in and around the engine and transmission to the firewall to install two brake cables for the ReadyBrake & the emergency breakaway braking system. Both are cable activated, connecting to the brake pedal arm through the firewall to the front of the fit. My initial thought is remove the right front wheel, and plastic wheel well panels, remove battery & air filter box to gain engine side access to firewall.
Any other recommendations/pictures anyone can provide for assistance?
As for wiring, I used a converter to use the Honda turn signals, and ALL wiring done under the dash. If no converter, you have to run to the rear to tap in directly to individual bulbs, and skip the high-mount brake light. The parts:
Hopkins 48955 diodes and Tow Ready 118158 Converter
Trace the wires from the back - they end at a plug at the fusebox where you can splice in everything. The SMI requires routing a cable and airhose bundle through the firewall, so I had the needed wires at hand from the m'home.
Steve
Install underway
Hi All -
Thanks for the feed back. Had a few weeks off for Rotator Cuff Surgery. Put the fit up on jack stands and started slow. Installed the blue ox baseplate, Hopkins wire package back to rear light, plug and play. Road master brake relay under dash along with a road master toggle switch for the radio fuse.
Went with the ready-brake and removed air box and battery for access to firewall. Added the RVI battery tender off the hot feed from the MHome umbilical.
Final adjustment for the brake system will not be done until the first road trip shake done behind the MHome, but Fit is back on the road as I went back to work 5/4.
